Results 11 to 20 of 21
Thread: MercuryX: New Album Based Media Interface
  1. #11
    Jun 2002
    TN
    Stine161:
    Interesting. I must say that I have only tried it so far with DirectX 8.1a. This is the SDK that I am using, and teh Runtime version that I have tested it with. I will try to run it on a machine here with DirectX9 and see what happens. I would assume that DirectX 9 should be compatible with versions before it, but that is that only thing that I could think would cause that error. Is there anyway you can try it on your machine with a version of DirectX 8.1?
    Thanks for trying it out... and let me know what you find.
    Thanks,
    Quincy
  2. #12
    Variable Bitrate Stine161's Avatar
    Apr 2002
    Alberta Canada
    same error with Direct X 8.1 on my other windows 2000 box...
    Starting to think its the OS....
  3. #13
    Jun 2002
    TN
    Stine161:
    After doing some testing, you can also get the error if you are not running 32-bit color. I forgot to put this in the requirements. I get the error if I am running 16-bit or lower. Try this with DX 8.1 and 9.
    Thanks,
    Quincy
  4. #14
    Apr 2002
    Alberta Canada
    It works now in DX9 but very slow load...
    Also works on DX8.1
  5. #15
    Jun 2002
    TN
    Stine161:
    This is because the first time you run the program, it syncs the database. This is where is runs through the MusicLocation that you specified, reads in the ID3 tags, then Inserts it into the database. The next time you load the app, it should be an average load time...
    Let me know,
    Quincy
  6. #16
    Newbie Mongrat's Avatar
    Mar 2003
    Originally posted by qjones
    Yes, I used MusicMatch to rip all of mine. This is also what I used to get my Album Art. And I was wondering, what all does the Super Tagging let you do in MusicMatch?
    What makes Super Tagging Different?
    Unlike the basic tagging feature, Super Tagging automates the tagging process; finding, adding, and creating tags for you. This makes tagging faster and more accurate, especially if tagging groups of files. Tip
    Super Tagging performs three, distinct functions:
    Lookup Tags - Finds and adds tags based on the file name of your tracks.
    Tag From Filename - Turns file names into tags.
    Rename Files - Renames files based on the available tags
    Sorry, I just cut n paste out of the musicmatch help prog.
    anyhow, its pretty handy, especially when you have a pile of Mp3s you downloaded with goofy filenames. It will rename the file name in the format you like.......
    ~Mong
  7. #17
    Jun 2002
    TN
    Mongrat:
    Thanks for the Info. That works really well actually. I gave it a list of mp3's and it caught most of the tags fine, and the file renaming is also very nice!
  8. #18
    Oct 2002
    Georgia
    One thing you might wanna try adding to this package is a feature that allows you to sync to ur computer for updating files.
    Just my 2 cents
    -Merc
    1996 Jeep Grand Cherokee
    [:::::::::.]99.9%
    Working On: Fixing wireless network interference
    Specs: 8.4inch vga touch, 1.?? ghz, 256 DDR, 4gig OS HD, 120gig Media HD, opus
  9. #19
    Jun 2002
    TN
    mercury:
    I have thought pretty long, and hard about this option, and the best way to implement it. So to figure this out I need some input from some of the people using it. There are many tricks that I could do, for writing the Sync function to handle all of the music if I enforce where the music/etc has to be. However if I want to make the program not care at all where, and how your music is stored, I cannot do some of these tricks. So I guess what I am wanting to know is, how do most people store there music, etc? Finally, did you try the program out? If so, what did you think, and do you have any other suggestions?
    Thanks,
    Quincy
  10. #20
    Oct 2002
    Georgia
    Personally I have all my mp3s in a directory then under each artists name, then album next. I also have just a folder for singles.
    Yes, I did try it out. I would love to use it as my interface as soon as you get all the things that u wanna get done, done. So keep it commin so far so good.
    -Merc
    [:::::::::.]99.9%
