Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: speed up win 2000 boot time
  1. #11
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Try using hibernate, or upgrade to XP home..
  2. #12
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    Originally posted by more mods
    STR is not an option for me. My 5.7L V8 takes lots of power to turn over. So I need the battery to be at its peek.
    What is the best boot time for 2000 that I can get?
    Then im sorry to say you have a weak battery. STR uses what? .000000000000000005ma? that aint anything compared to what your battery can output. Like I said you NOT going to get any good boot times with win2k. Change your OS to winXP. " haha I would not call that an upgrade but hey thats me"
  3. #13
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    The guidelines for power usage in STR (S3/Standby) calls for the PC to be roughly using 20% of its typical power. So if you have a 100w pc, STR is still using a sizable amount of power (hence its refered to as light sleep). And even if you have a dimunitive 50w pc, you'd still be drawing .8a. S4 (STD/Hibernate) uses much less, but takes much longer too boot back up.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
  4. #14
    Dec 2002
    Chico, Ca
    My understanding with STR is that the only power left is just enough to keep the ram refreshed, everything else is dead. In this case the power draw is probably only a few watts if that.
    Once I get my setup finished with my new DC-DC power supply I will be testing how long I can stay in STR because I use my only once a week, if that.
  5. #15
    Jun 2003
    I'd investigate hibernation too - you should be able to do this with Win2K.
    You can set your machine to STR after a certain time, then have the machine wake and hibernate after a period of time in STR state.
    Whether you can trigger the hibernate following STR without going into STR through a timeout, I don't know, but it's worth a play
    Hibernate serialises your memory and state to disc, and takes zero power. All that'll be running is your +5V standby line, which draws next to bugger all.
    Boot time for me from hibernated takes around 20 seconds.
    Cheers,
    Nick.
  6. #16
    Jan 2002
    Chicagoland, IL
    Hibernate/S4/STD "boot" times can wildly vary. I think I was looking at 30+ seconds when I played with it breifly on a duron 750 and 512 ram. It depends heavily on how much ram you have, and how quick your hd is. It can also take a while to hibernate, as it writes however much ram you have to disk.
    -Nick
