Results 1 to 10 of 14
Thread: Auto dimmer (with GPS or LON/LAT position)
    Dec 2010
    Cool Auto dimmer (with GPS or LON/LAT position)
    NEW: Dimmer now supports GPS-Receivers with NMEA protocols.
    remember that this is a beta version, cause i don't had much time to test, so please give me feedback!
    I just coded a program that automatically dims your monitor gamma.
    It locates at your position (lonitude & latitude) where the sun is and dim the monitor if its dark.
    Also you have a manual mode any MANY more really nice features.
    If you set the COM port to "none", the manual lat and long settings are used!
    Mirror of file: AutoAppMart
    If you find any bug please let me know!
    Changelog v3.1b1 since v2.1b2:
    -Added Trigger Box feature to change the dimming mode manually
    -Now Lonitude and Latitude can be set by GUI
    -no dimmer.ini is needed anymore, all set by GUI
    -now an offset can be set for manual sunrise/sunset differences
    -many bugfixes
    Changelog v2.1b2:
    -various fixes
    Changelog v2.1b1:
    -Changed to another sun position algorithm
    -now checks for a valid NMEA device before com port is set
    -no timezone to set anymore. its calculated by longitude
    Changelog v2.0b:
    -Added GPS-Receiver support with NMEA protocol
    -put some settings to the registry instead of the ini file
    -cleaned up the code
    -some other fixes
    Changelog v1.2:
    -Solved hibernation problems, because path to ini file lost
    -ini file now automatically created if it not exists
    Changelog v1.1:
    -custom brightness can be set (20%-50%)
    -Now the Timezone will be considered (please set this in dimmer.ini on utc=)
    -If Centrafuse or other programs change the Brightness, dimmer change it back again
    -All settings like brightness and the last active mode will be saved on exit
    -more stable
    Attached Files Attached Files
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    sounds like what my plugin AutoDimmerControl does for CF. Wonder if you had as much trouble converting the lat/lon values to adjusted time values lol. Good work. Put it up on AutoAppMart and i bet it'll receive some love!
    Live mp3Car Facebook Chat
    Dec 2010
    Updated, mor stable now and it gets darker ;-)
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Looks great. I'll give this a try..
    Dec 2010
    I'll be happy if i get som feedback ;-)
    thanks!
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Sure can't download it. Attachments are invalid link and the appstore file has 0 bites..?????
    Dec 2010
    Quote Originally Posted by MGD View Post
    oops...
    works now
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Got it. Works great. Just one question, is it possible to get the LAT and LON from the GPS as the current location?
    Feb 2011
    yes that would be an awesome feature as I travel a lot.
    May 2010
    Herákleion, Iraklion, Greece, Greece
    man thank you, i was searching for somethinglike that for like years!! so simpole, yet so usefull!
  1. OBD2 throttle position PID
    By nambaliya in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-01-2010, 04:41 AM
  2. Replies: 222
    Last Post: 09-21-2010, 12:39 PM
  3. System Metric Values
    By ssteger in forum VaultWiki
    Last Post: 02-11-2010, 10:26 AM
  4. Noise interference from auto air adapter
    By hardcoreracing in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 03-13-2008, 10:46 PM
  5. Auto DJ function proposal.
    By kid320 in forum Media Engine
    Last Post: 07-26-2004, 05:35 PM
