Results 1 to 10 of 11
Thread: speedin up win 98
    Constant Bitrate cubanmoses's Avatar
    May 2003
    miami/orlando
    Question speedin up win 98
    my windows 98 boots very slow, and i was wondering on what i could do to speed it up. i've been researching on how to do, and i only have winamp as my only application starting up. i've deleted a lot of files on the computer already. i want to use the comp for playing mp3s and dvds for now. i have a toshiba laptop and i can't get into the bios by pressing the f2 key at start up. i'll be happy with a 40 second boot time. my boot time is at 50 plus seconds, i just timed it at 57 seconds.
    Mar 2003
    I assume you checked the BIOS for things to turn off. I know laptops usually don't have a lot of extras to disable but I just shaved off 12 secconds taking out a RAID controller I wasn't using anymore.
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    You haven't provided enough information to know if this will work for you, but have you considered making your application for playing mp3/DVD (ie AutoPlay or MediaEngine) your shell, rather than explorer?
    C!
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
    May 2003
    miami/orlando
    i hope to get gps later on in the future, but gps, dvds and mp3s will seem to be all that i will use the laptop for. i'm kinda inclined to use winamp cause i took time and putting the playlist info for a bunch of my songs.
    also, i hold down the f2 key or ctrl when the comp boots and i can't get into the bios. do the other windows os boot faster or would installing win 98 on it from scratch be the best option?
    project: built, updating software
    comp: 1.67 ghz AMD, 1 gig of ram, 80 gb hd
    software: nlited xp, roadrunner
    screen: TM-701L touchscreen
    bluetooth keyboard
    Sony Xplod cdx-m630
    SB MP3 sound card
    future: gps with and navigation software
    Constant Bitrate GRUNT's Avatar
    Sep 2002
    Scotland
    Things to try:
    Disable/remove network hardware/software
    Disable any harware you do not use.
    You should not need to run config.sys or autoexec.bat
    Check your harddisk for errors then Defrag.
    Run MSCONFIG.EXE check the under startup, look for any programs running you don't need.
    Look at your SYSTEM.INI and WIN.INI make sure they are nor running any thing you don't need.
    All system are not the same so you will have to experement.
    Also your system may be looking for or running a program that is not working so windows may be waiting for it to timeout.
    NOTE: DONOT delete any file, if you donot know what it is.
    Rename them i.e. netsys.exe netsys.exx
    This way you can restore the file.
    Hope some of this helps you.
    Aug 2002
    San Francisco, CA USA
    IDE Flashdrive
    Have you considered an IDE flashdrive for the OS alone to speed up booting?
    2001 740Il - Jet Black with MkIII and more...
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    I'm stunned that no-one has suggested 98lite. www.98lite.net i think
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Re: IDE Flashdrive
    Its true that flashdrives have 0 seek time, but their transfer rates are much slower than even ata33 drives. Win98 can only be made to boot so fast on an old laptop. What's the hardware specs of the hardware?
    -Nick
    _____________________________
    www.mp3vw.com
    Oct 2002
    Alaska
    are there any free alternatives to this?
    Jan 2003
    Ruston, LA
    they offer a free version with less features
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
