program the change resolution on exe.
is there a program that will change my res on the lauch and then restore the defult res back once you eiit the program?
white bream working on a trilogy: CARGO - UNIGO - MERGO
CARGO = the Car Computer
Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
If you are running windows XP, you can automatically switch into 640x480 when an app launches, and then back to your original desktop res after it exits.
Just right click on the .exe, select properties
then the compatibility tab
then check the "run in 640x480" screen resolution.
That is, assuming 640x480 is the resolution you want to run in :-)
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
