Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Any Virtual Machine users?
  1. #11
    Maximum Bitrate Borte's Avatar
    Jan 2006
    Norway
    Quote Originally Posted by Tidder View Post
    Is that a per VM thing or VMPlayer? I'm wondering if it will open on the display that vmplayer was last open on, regardless of which VM was running. That may pose a problem.
    Yeah it does in fact seem that way. I don't have a proper player setup here so I only made a quick test but it seems to restart on the screen that the player was last used at.
    Failure is not an option...
    __________________________________________________ ______________________________
    The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
  2. #12
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Well I am hoping it works. For the extra VM units, I will not use the VMplayer icon to start them up. Instead I will use the config fill so I can go straight to the VM machine. I then plane to put a shortcut on each display to its respective config file. I wish I could test myself but the machine I am using doesn't seem to want to accept more then one pointer device, so I will take Borte's test as being accurate.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  3. #13
    Jan 2006
    Norway
    Well... It's accurate to the fact that the vm you start will restart in the location of the last vm you shutdown.
    I think it might be relatively easy to write a small program that starts the shourtcut and then moves it to the correct screen instead. I'll have a look about how much work it would be.
  1. virtual machine
    By craig131 in forum VaultWiki
    Last Post: 01-03-2010, 06:56 PM
  2. Parallels Desktop Windows Virtual Machine?
    By miscrms in forum MacCar
    Last Post: 02-20-2007, 12:01 AM
  3. Setting 800x480 in a VMWare player virtual machine
    By timeshifter in forum Road Runner
    Last Post: 06-28-2006, 11:40 PM
  4. virtual machine player
    By kraft in forum Linux
    Last Post: 03-04-2006, 03:32 PM
