Page 11 of 19 FirstFirst ... 2345678910111213141516171819 LastLast
Results 101 to 110 of 183
Thread: Wanted: Programmer who wants to play with DAB+ option
  1. #101
    Dec 2011
    Quote Originally Posted by wintertidenz View Post
    I looked in the BlazeVideo directory and found some Realtek plugins, it may be worth looking at these to see if they hold any clues?
    An update on the BlazeDTV realtek plugins...
    ... looks like they are doing exactly the same sort of thing that I am trying with version 2 of my plugin for Radiator but they have 3 extra API calls which I did not include, so I wonder if the key to this is those missing calls. The SDK and reference manuals from Realtek only mention 2 of the 3 calls, so Blaze must know something I don't.
    Might have a workaround. Any ideas who the lead developer of RR and Centrafuse is? I may have an idea.
  2. #102
    Jan 2009
    Talk to BlueZX3 - I think he's the lead dev of Riderunner.
    The DVB units are actually pretty cheap, this is what I bought:
    http://www.dealextreme.com/p/ultra-m...-dab-dab-47015
    There is a significant size difference between the Realtek program and the one you posted up just before - 613KB for Realtek FM, 97KB for your FM build. 1.52MB for the Realtek DAB build, 228KB for yours.
    Your one seems to crash for the DAB when started, error:
    DABPlayer_20100114_SDK.exe - Unable To Locate Component
    This application has failed to start because MFC42D.DLL was not found. Re-installing the application may fix this problem.
    OK
    The FM one seems to launch and scan channels OK but crashes on play. This happens on Win 7 and XP.
    Error:
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: FMPlayer_091207.exe
    Application Version: 1.0.0.1
    Application Timestamp: 4f0125fc
    Fault Module Name: StackHash_0a9e
    Fault Module Version: 0.0.0.0
    Fault Module Timestamp: 00000000
    Exception Code: c0000005
    Exception Offset: 00000000
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 5129
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
  3. #103
    May 2010
    Australia
    Good work guys.
    Will try to squeeze some testing in at some stage but it might not be anytime soon
  4. #104
    Jun 2006
    Hey guys, great work so far. I hope this gets finished.
    To help out, I will get one of these in a day or so:
    http://www.ebay.com.au/itm/ezcap-USB...item3f08baf953
    Then I should be able to test for you also. I am keen to see this work
  5. #105
    Nov 2011
    Hey there, thanks for the great work again ! I am quite sure, we are very close to it !
    This is the logfile of my PC, i used the second pluginfile you posted !
    By the way, after starting radiator and clicking on "settings" I get an alert saying:
    "Access violation at address 004E3E0D in moduke 'radiator.exe'. Read of address 000000B4"
    This is, what my logfile says:
    [10243D70 10243E40] Call to DllMain succeeded.
    [10243D70 10243E40] HWInit: Trying to init RTL2832 hardware.
    [10243D70 10243E40] HWInit: Found DAB compatible installed package.
    [10243D70 10243E40] HWInit: DAB device failed to open (is it already in use?)
    [10243D70 10243E40] GetModuleInfo() returned capabilties: FM_TUNE, FM_CONFIGURATIONDIALOG.
    [10243D70 10243E40] TuneFreq: Tune request to 106700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 106800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 106900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 107000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 107100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 107200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 107300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 107400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 107500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 107600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 107700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 107800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 107900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 108000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 108100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 108200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 108300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 108400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 108500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 108600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 108700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 108800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 108900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 109000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 109100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 109200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 109300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 109400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 109500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 109600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 109700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 109800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 109900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 110000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 110100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 110200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 110300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 110400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 110500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 110600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 110700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 110800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 110900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 111000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 111100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 111200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 111300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 111400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 111500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 111600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 111700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 111800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 111900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 112000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 112100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 112200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 112300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 112400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 112500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 112600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 112700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 112800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 112900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 113000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 113100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 113200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 113300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 113400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 113500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 113600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 113700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 113800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 113900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 114000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 114100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 114200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 114300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 114400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 114500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 114600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 114700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 114800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 114900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 115000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 115100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 115200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 115300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 115400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 115500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 115600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 115700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 115800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 115900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 116000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 116100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 116200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 116300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 116400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 116500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 116600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 116700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 116800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 116900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 117000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 117100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 117200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 117300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 117400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 117500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 117600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 117700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 117800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 117900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 118000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 118100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 118200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 118300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 118400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 118500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 118600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 118700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 118800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 118900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 119000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 119100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 119200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 119300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 119400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 119500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 119600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 119700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 119800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 119900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 120000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 120100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 120200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 120300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 120400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 120500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 120600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 120700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 120800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 120900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 121000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 121100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 121200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 121300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 121400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 121500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 121600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 121700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 121800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 121900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 122000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 122100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 122200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 122300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 122400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 122500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 122600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 122700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 122800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 122900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 123000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 123100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 123200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 123300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 123400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 123500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 123600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 123700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 123800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 123900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 124000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 124100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 124200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 124300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 124400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 124500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 124600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 124700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 124800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 124900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 125000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 125100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 125200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 125300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 125400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 125500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 125600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 125700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 125800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 125900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 126000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 126100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 126200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 126300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 126400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 126500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 126600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 126700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 126800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 126900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 127000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 127100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 127200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 127300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 127400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 127500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 127600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 127700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 127800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 127900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 128000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 128100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 128200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 128300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 128400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 128500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 128600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 128700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 128800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 128900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 129000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 129100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 129200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 129300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 129400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 129500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 129600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 129700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 129800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 129900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 130000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 130100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 130200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 130300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 130400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 130500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 130600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 130700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 130800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 130900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 131000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 131100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 131200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 131300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 131400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 131500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 131600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 131700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 131800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 131900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 132000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 132100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 132200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 132300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 132400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 132500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 132600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 132700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 132800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 132900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 133000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 133100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 133200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 133300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 133400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 133500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 133600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 133700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 133800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 133900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 134000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 134100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 134200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 134300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 134400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 134500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 134600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 134700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 134800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 134900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 135000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 135100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 135200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 135300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 135400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 135500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 135600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 135700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 135800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 135900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 136000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 136100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 136200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 136300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 136400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 136500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 136600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 136700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 136800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 136900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 137000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 137100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 137200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 137300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 137400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 137500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 137600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 137700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 137800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 137900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 138000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 138100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 138200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 138300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 138400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 138500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 138600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 138700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 138800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 138900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 139000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 139100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 139200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 139300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 139400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 139500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 139600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 139700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 139800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 139900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 140000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 140100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 140200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 140300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 140400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 140500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 140600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 140700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 140800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 140900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 141000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 141100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 141200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 141300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 141400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 141500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 141600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 141700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 141800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 141900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 142000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 142100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 142200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 142300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 142400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 142500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 142600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 142700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 142800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 142900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 143000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 143100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 143200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 143300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 143400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 143500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 143600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 143700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 143800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 143900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 144000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 144100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 144200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 144300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 144400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 144500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 144600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 144700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 144800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 144900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 145000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 145100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 145200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 145300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 145400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 145500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 145600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 145700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 145800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 145900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 146000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 146100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 146200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 146300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 146400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 146500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 146600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 146700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 146800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 146900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 147000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 147100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 147200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 147300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 147400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 147500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 147600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 147700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 147800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 147900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 148000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 148100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 148200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 148300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 148400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 148500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 148600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 148700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 148800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 148900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 149000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 149100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 149200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 149300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 149400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 149500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 149600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 149700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 149800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 149900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 150000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 150100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 150200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 150300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 150400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 150500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 150600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 150700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 150800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 150900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 151000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 151100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 151200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 151300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 151400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 151500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 151600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 151700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 151800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 151900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 152000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 152100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 152200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 152300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 152400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 152500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 152600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 152700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 152800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 152900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 153000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 153100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 153200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 153300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 153400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 153500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 153600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 153700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 153800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 153900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 154000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 154100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 154200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 154300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 154400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 154500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 154600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 154700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 154800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 154900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 155000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 155100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 155200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 155300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 155400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 155500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 155600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 155700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 155800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 155900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 156000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 156100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 156200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 156300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 156400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 156500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 156600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 156700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 156800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 156900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 157000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 157100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 157200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 157300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 157400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 157500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 157600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 157700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 157800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 157900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 158000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 158100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 158200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 158300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 158400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 158500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 158600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 158700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 158800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 158900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 159000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 159100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 159200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 159300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 159400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 159500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 159600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 159700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 159800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 159900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 160000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 60000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 60100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 60200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 60300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 60400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 60500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 60600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 60700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 60800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 60900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 61000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 61100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 61200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 61300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 61400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 61500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 61600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 61700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 61800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 61900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 62000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 62100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 62200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 62300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 62400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 62500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 62600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 62700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 62800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 62900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 63000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 63100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 63200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 63300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 63400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 63500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 63600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 63700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 63800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 63900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 64000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 64100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 64200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 64300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 64400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 64500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 64600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 64700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 64800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 64900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 65000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 65100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 65200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 65300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 65400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 65500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 65600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 65700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 65800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 65900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 66000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 66100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 66200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 66300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 66400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 66500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 66600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 66700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 66800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 66900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 67000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 67100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 67200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 67300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 67400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 67500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 67600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 67700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 67800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 67900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 68000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 68100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 68200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 68300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 68400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 68500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 68600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 68700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 68800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 68900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 69000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 69100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 69200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 69300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 69400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 69500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 69600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 69700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 69800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 69900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 70000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 70100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 70200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 70300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 70400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 70500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 70600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 70700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 70800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 70900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 71000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 71100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 71200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 71300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 71400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 71500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 71600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 71700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 71800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 71900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 72000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 72100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 72200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 72300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 72400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 72500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 72600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 72700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 72800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 72900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 73000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 73100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 73200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 73300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 73400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 73500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 73600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 73700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 73800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 73900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 74000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 74100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 74200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 74300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 74400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 74500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 74600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 74700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 74800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 74900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 75000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 75100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 75200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 75300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 75400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 75500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 75600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 75700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 75800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 75900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 76000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 76100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 76200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 76300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 76400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 76500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 76600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 76700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 76800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 76900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 77000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 77100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 77200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 77300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 77400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 77500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 77600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 77700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 77800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 77900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 78000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 78100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 78200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 78300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 78400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 78500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 78600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 78700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 78800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 78900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 79000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 79100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 79200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 79300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 79400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 79500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 79600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 79700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 79800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 79900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 80000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 80100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 80200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 80300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 80400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 80500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 80600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 80700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 80800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 80900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 81000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 81100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 81200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 81300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 81400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 81500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 81600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 81700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 81800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 81900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 82000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 82100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 82200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 82300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 82400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 82500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 82600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 82700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 82800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 82900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 83000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 83100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 83200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 83300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 83400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 83500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 83600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 83700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 83800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 83900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 84000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 84100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 84200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 84300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 84400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 84500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 84600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 84700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 84800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 84900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 85000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 85100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 85200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 85300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 85400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 85500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 85600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 85700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 85800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 85900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 86000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 86100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 86200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 86300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 86400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 86500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 86600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 86700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 86800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 86900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 87000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 87100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 87200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 87300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 87400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 87500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 87600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 87700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 87800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 87900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 88000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 88100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 88200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 88300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 88400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 88500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 88600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 88700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 88800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 88900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 89000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 89100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 89200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 89300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 89400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 89500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 89600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 89700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 89800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 89900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 90000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 90100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 90200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 90300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 90400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 90500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 90600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 90700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 90800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 90900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 91000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 91100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 91200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 91300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 91400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 91500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 91600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 91700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 91800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 91900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 92000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 92100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 92200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 92300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 92400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 92500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 92600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 92700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 92800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 92900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 93000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 93100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 93200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 93300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 93400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 93500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 93600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 93700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 93800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 93900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 94000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 94100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 94200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 94300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 94400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 94500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 94600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 94700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 94800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 94900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 95000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 95100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 95200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 95300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 95400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 95500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 95600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 95700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 95800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 95900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 96000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 96100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 96200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 96300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 96400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 96500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 96600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 96700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 96800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 96900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 97000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 97100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 97200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 97300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 97400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 97500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 97600kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 97700kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 97800kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 97900kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 98000kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 98100kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 98200kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 98300kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 98400kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 98500kHz received from Radiator
    [10243D70 10243E40] TuneFreq: Tune request to 106700kHz received from Radiator
    [10243D70 10243E40] Call to DllMain succeeded.
    [10243D70 10243E40] GetModuleName() returned string: Realtek 2832U.
    [10243D70 10243E40] GetModuleInfo() returned capabilties: FM_TUNE, FM_CONFIGURATIONDIALOG.
    [10243D70 10243E40] HWDeInit: Trying to close DAB device...
    [10243D70 10243E40] HWDeInit: DAB device failed to close (maybe it wasnt open?)
    [10243D70 10243E40] HWInit: Trying to init RTL2832 hardware.
    [10243D70 10243E40] HWInit: Found DAB compatible installed package.
    [10243D70 10243E40] HWInit: DAB device failed to open (is it already in use?)
  6. #106
    Dec 2011
    Hi guys,
    Sorry its been a few days since I've been here as life has suddenly got hectic. I had another idea for this which would almost certainly 100% work. I think for the sake of getting things going it will be easier to concentrate on getting standard FM radio working via the Radiator plugin first, and then moving on to DAB/DAB+ as I understand that currently Radiator receives absolutely nothing through this cheap and useful 2832 chip.
    I need to order one of this little receivers to be able to continue, otherwise I'm shooting in the dark really. I'll see about getting one over the next few days. eBay is cheapest?? or anyone know of another cheaper supplier?
    L
  7. #107
    May 2010
    Australia
    Yeah I think ebay might be the best bet.
    Sounds like a good plan
  8. #108
    Nov 2011
    I would like to support you with 2 dollars, if you will get the fm radio going with radiator.
    I did not get the skills but you got them, I guess.
    If you send me your paypal adress, I'd like to send you a small aid.
  9. #109
    May 2006
    Hi guys
    Bit of a lurker here. Can someone point me at the SDK please?
  10. #110
    Jan 2012
    Questions about FMPlayer_091207 and DABPlayer_20100114_SDK.
    hello all together,
    i am owner of a noxon usb dab stick, which comes with a software called "noxon media player". with this software i can receive dab and dab+ signals. the noxon usb dab stick is based on the realtek rtl2832 chip. now i was searching für software und the driver which gives me the chance to watch dvb-t and listen to fm radio with this usb stick.
    my machine runs windows 7 professional.
    at first i deleted the driver that comes with the noxon usb dab stick and installed the driver that are mentioned here by laimcrayden on 1-1-2012. then i installed the radiotor plugin. at least i replaced the dll by the one mentioned by him a few pages later (RTL2832U_T3.zip).
    now i installed the two programs FMPlayer_091207 and DABPlayer_20100114_SDK. both worked with my noxon usb dab stick. even the original noxon media player software works with the now installed drivers. so far anything seem to be ok, but i have some questions and hope someone of you experts can give me answers:
    the DABPlayer_20100114_SDK receives dab and dab+ signals at the same time, because both signals are broadcasted together at one frequency here in germany. but the software does not play the dab+ signals. does anyone know how to improve the software in order to receive and playback dab+ signals ?
    bye the way... as long as i tune to a dab station the signal is more stable compared to the noxon media player software, which is made by fraunhofer institute.
    is there any newer version from DABPlayer with covers dab+ ?
    the FMPlayer_091207 works fine with my noxon usb dab stick, but when i close the program, all stations are forgotten and i have to scan again. is there any function to store the station list and reload the list instead of scanning every time ?
    Is there a newer version of the FMPlayer ?
    does anyone know any other software for FM or DAB+ that works togehter with the realtek chip and the drivers ?
    Thanks a lot fdb123
  1. M4-ATX Programmer
    By phrasius in forum Newbie
    Last Post: 06-29-2008, 03:57 PM
  2. PIC Programmer
    By meddler in forum General Hardware Discussion
    Last Post: 04-26-2008, 11:45 PM
  3. WANTED - PHIDGITS Programmer / Hacker
    By SEGgeek in forum MacCar
    Last Post: 12-06-2006, 03:52 PM
  4. WTD: USB pic programmer
    By lez in forum Classified Archive
    Last Post: 07-07-2006, 07:23 AM
  5. Pic Programmer
    By KyleYankan in forum Hardware Development
    Last Post: 05-02-2005, 01:04 AM
