Page 14 of 18 FirstFirst ... 456789101112131415161718 LastLast
Results 131 to 140 of 178
Thread: Wanted: Programmer who wants to play with DAB+ option
  1. #131
    Oct 2010
    Hi Guys,
    I haven't had any luck getting the SDK with the source for the player apps, if anyone has a copy of it please PM me so we can work something out, I'm certainly willing to give this a go!
  2. #132
    Jan 2012
    There seems to be a few members who have obtained the SDK so I hope you can have a look, I am a bit pessimistic though there has been at least 2 peaks in this thread each of which has culminated in various people working with it but then it goes quiet so I am assuming this is a very difficult nut to crack, anyway good luck with the quest.
  3. #133
    Nov 2011
    Any news how far the awesome proggers got ?
    Did any one get it working with radiator or as a single plugin for centrafuse ?
    Can anyone send me the SDK for the FMPLAYER please ?
    I would like to try to write a plugin for Centrafuse.
    Greetings
  4. #134
    Feb 2010
    Quote Originally Posted by listener View Post
    The SDK I received is a few PDF documents and doesn't come with any kind of reference drivers or sample code. Using the drivers I found on this thread I've managed to create a C# library which implements all of the documented API for FM radio (using the DirectShow.Net library for the DirectShow audio bits). I'm currently putting together a test application to demonstrate the use of this C# library and then hope to write a plugin to integrate it with something. If Realtek are happy with the idea then I'll stick it on CodePlex so that others can use the code.
    The next stage is DAB/DAB+. MY DAB reception is pretty poor but once I get an aerial I should be able to write a library to do that too. DAB+ may be trickier since I can't get that but I'm hoping that it's just a slight change to the DirectShow filters.
    As I said, I'd like to get something up on CodePlex (or other open source hosting) so that others can write plugins against a library and not have to worry about the implementation details. There are definitely some 'inconsistencies' between the documentation and drivers I have so it'd be nice to think that we all don't have to solve the same problems.
  5. #135
    Jan 2009
    Sorry guys I've been quite busy with work. I'm trying to convince one of my workmates to build a skin-friendly app for this, as all I was given was C# which I'm not so familiar with.
    Also, I was given the DAB SDK stuff only - and was told that once I get DAB working, then FM is quite easy from there.
  6. #136
    Nov 2011
    Summarizing this all doesn't really sound bad, does it ?
    So if anybody needs a beta-tester, here I am
    If there is anything I can do to help, just let me know, I really want to get this working !!
    So far, yours OEKL ;-)
  7. #137
    Feb 2012
    Quote Originally Posted by alnicol View Post
    alnicol your other options for code hosting are Bitbucket and GitHub. If you want me to, I can start the repository for you somewhere. Are you already using source control locally? I am in a DAB+ area so I'm very interested in working on this with you!
  8. #138
    Feb 2012
    Hey alnicol, can I take a look at the code you have? I also got the SDK - however my copy came with a VC6 (yes, 6) sample app for DVB, but no FM.
  9. #139
    May 2006
    Hey guys,
    I put a few PMs out to those saying they have the SDK. I've fired off an email to Realtek Taiwan a little while ago and so far have only had read receipts (about 6 or 7 though) which all happened quite fast.
    Also, it seems there are a couple of different "versions" of the so-called SDK.
    I'm mostly interested in DAB for my car PC (BMW CarMedia) but DVB and FM might be nice to integrate particularly if RDS etc is supported
    Can anyone help me out with a copy of the SDK?
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    pm sent :-)
  1. M4-ATX Programmer
    By phrasius in forum Newbie
    Last Post: 06-29-2008, 02:57 PM
  2. PIC Programmer
    By meddler in forum General Hardware Discussion
    Last Post: 04-26-2008, 10:45 PM
  3. WANTED - PHIDGITS Programmer / Hacker
    By SEGgeek in forum MacCar
    Last Post: 12-06-2006, 02:52 PM
  4. WTD: USB pic programmer
    By lez in forum Classified Archive
    Last Post: 07-07-2006, 06:23 AM
  5. Pic Programmer
    By KyleYankan in forum Hardware Development
    Last Post: 05-02-2005, 12:04 AM
