Page 18 of 19 FirstFirst ... 8910111213141516171819 LastLast
Results 171 to 180 of 183
Thread: Wanted: Programmer who wants to play with DAB+ option
  1. #171
    Nov 2012
    Brisbane, Australia
    Hi there,
    I just read this thread and I am wondering what has been happening with the results?
    It's been over 6 months since the last reply, so does that mean the project is dead?
    That main reason I ask is I am very interested in adding a DAB+ feature to my car-pc and as I've already written an mp3 player for it, was also interested in seeing if I could add DAB support to it too...
    I have searched the internet about it a fair bit and it seems it might be fairly tricky to do, esp without any SDK :P
    So how are the results going, and do you need any help?
    Andrew.
  2. #172
    May 2006
    Quote Originally Posted by shukamanon View Post
    Hi there,
    Andrew.
    The SDK is pretty average and doesn't give access to all the DAB+ info. Not sure if there's any real way around it using the supplied drivers/interface.
    Also I couldn't get the DirectShow filters to work unless I installed the rubbish software that came with it. Even though it appeared to support FFDshow I couldn't get it to properly decode the DAB+ AAC codecs here in Brisbane. I did succeed in a very basic tune using the C# work that one of the others here used (alnicol)
    The RTL-SDR are doing everything from scratch but seem more interested in receiving things other than normal radio e.g. GSM, LTE etc.
    I haven't found any other software or code that can use this stick as a regular DAB/DAB+ tuner.
  3. #173
    Nov 2012
    Brisbane, Australia
    I don't actually have that stick but have a kaiser baas one, and I'm sure none of the sticks out there will be compatible with any other brand of stick, so the main problem in writing some kind of software to access DAB+ would be to choose a stick which gave you the easiest way of accessing it, or has the best SDK support to help understand how to utilize it to the fullest.
    The software that comes with the kaiser baas is a joke, which is one of the main reasons why i wish to write my own interface, though i have no problems in buying a different brand one if that will make things easier for me
    Also good to see you are also in Brisbane as I am too :P
  4. #174
    May 2006
    If it's still the RTL2832 chipset it should be all basically the same and the SDK should work. Is yours an RTL2832?
    I don't understand where the tuner part fits in though since some of the devices come with different tuners (talked about on the RTL-SDR mailing list)
    Yes, there are no standards for any of this sort of DAB/DAB+ driver it seems which makes it quite difficult to support across multiple devices.
    The ezcap software is functional and works but is pretty crappy even though it's a commercial product. The SDK demo is just enough to play a station. However even then it won't play DAB+ like we have with just the drivers installed. It needs the codec from the commercial package to decode the AAC stream.
  5. #175
    Nov 2012
    Brisbane, Australia
    I just found a good website:
    http://linuxtv.org/wiki/index.php/DVB-T_USB_Devices
    Which lists most usb sticks...
    The kaiser baas uses the 'DiB7770P' hardware, and it seems to be the only stick that uses that type
    I have no problems in buying a different stick, as they are all very affordable. I might have to do some more research to find which model would be a better choice for programming it, has ease of use, features, etc...
    Unless you think the RTL2832 chipset ones are the way to go?
    I see they list a stick there for ezcap too which uses the RTL2832, is that yours?
    On the programming side of things. The DLLs which comes with the stick should be all you need to do everything, all you need to do is work out what are all the functions and how they work... And with streaming audio, well that sounds like it will get fairly complicated...
  6. #176
    May 2006
    It's a bit more complicated than just some DLL calls. The way the SDK works is you set up DirectShow filter chains to do the decoding. Also the DLL doesn't expose a few things like song data etc that can be sent alongside the actual audio.
    Yes the model I have is an ezcap and really I'm looking for a Windows solution since the rest of my CarPC software is written in .NET 2.0
  7. #177
    Sep 2012
    Brisbane, Australia
    Quote Originally Posted by Shonky* View Post
    Hi all,
    I've been keeping a pretty keen eye on this thread since starting my carputer build in my Nissan Patrol 3 months ago. I've nearly got everything working based on all the forums except for GPS and FM/DAB+ radio.
    I purchased this EZcap USB radio from here http://dx.com/p/dvb-t-digital-tv-usb...-dab-dab-44326 for $20 delivered to Brisbane last month.
    I have managed to get normal FM working through the crappy software it comes with, but not integrated into RR, but I'd like to get working well in RR. Has anyone been able to do this? It uses the aforementioned RTL2832 chipset too.
    Another issue I'm having is when this is plugged into a USB hub it can be a little intermittent with working. Maybe this would be better suited to being plugged in directly to the motherboard's usb port rather than a hub? Any suggestions?
    Hope to hear that someone in AUS has the same setup as me (or very similar) and has it working!
    Cheers,
    Jared
  8. #178
    May 2006
    I got some basic stuff working yes but the SDK is very limited and doesn't provide some of the nice features like now playing, images etc. It required specific DirectShow filters to work for DAB+ in my experience. I needed the included software to get it to work.
    I'm probably going to head down this path now:
    http://www.mp3car.com/hardware-devel...ent-board.html
    It has to use an analogue line out to a line in of your PC and it's not really a commercial product (i.e. it needs a case in particular) but it seems to be much better supported in terms of an SDK (although it's a little clunky)
  9. #179
    Jan 2006
    Dublin, Ireland
    Where can I get the latest possible driver for the 2832U which will work for DVB-T on XP ? I'm running RR and want to use the in-built VLC to play TV using an RTL 2832U based DVB-T USB Stick. Would the RTL2832U_T3.zip file from earlier in this thread possibly work ?
  10. #180
    Jan 2015
    Stuttgart (48.79N/9.19E)
    Hello everybody,
    I am glad to have found people who are familiar with FMPlayer_091207.exe with which I have some problems.
    I am using a RTL2832U/Elonics E4000 stick named Terratec ran-T Stick+ which is widespreaded here in Germany. It works fine with DAB Player on local DAB and DAB+ stations same on DVB-T in DVB Viewer Pro on 8.1. Even on Win 7 in VMWare Player DAB Player runs flawlessly.
    Having found FMPlayer_091207.exe in this thread here I would like to get it running. The application is starting up fine and everything seems to be working as it should. The scan finds plenty of stations even weaker ones but when I click on any to play it is crashing showing me up this:
    Problemsignatur:
    Problemereignisname: APPCRASH
    Anwendungsname: FMPlayer_091207.exe
    Anwendungsversion: 1.0.0.1
    Anwendungszeitstempel: 4f0125fc
    Fehlermodulname: StackHash_4b9e
    Fehlermodulversion: 0.0.0.0
    Fehlermodulzeitstempel: 00000000
    Ausnahmecode: c0000005
    Ausnahmeoffset: PCH_4A_FROM_ntdll+0x0003AAAC
    Betriebsystemversion: 6.3.9600.2.0.0.256.48
    Gebietsschema-ID: 1031
    Zusatzinformation 1: 4b9e
    Zusatzinformation 2: 4b9e06944c522e4ca3220287c0659b2c
    Zusatzinformation 3: 55a7
    Zusatzinformation 4: 55a78cca3676f1f6a5d28696b305bb6a
    You might be confused because of the expressions in german. That's because this is my OS's language but that should not be the cause.
    I look forward in hearing some propositions in how to get rid of this.
    Thank you very much indeed for spending time.
    Best regards from Stuttgart.
  1. M4-ATX Programmer
    By phrasius in forum Newbie
    Last Post: 06-29-2008, 03:57 PM
  2. PIC Programmer
    By meddler in forum General Hardware Discussion
    Last Post: 04-26-2008, 11:45 PM
  3. WANTED - PHIDGITS Programmer / Hacker
    By SEGgeek in forum MacCar
    Last Post: 12-06-2006, 03:52 PM
  4. WTD: USB pic programmer
    By lez in forum Classified Archive
    Last Post: 07-07-2006, 07:23 AM
  5. Pic Programmer
    By KyleYankan in forum Hardware Development
    Last Post: 05-02-2005, 01:04 AM
