beurk!
http://www.nokia.com/nokia/0,4879,5778,00.html
Wow.... Saw this on the Dash PC forum and when for a look.... impresive....
Can an interface be programed to work with Media Engine or a like - no screen would needed then.
Full Specifications
Dual-band EGSM 900/GSM 1800 operation
Internal SIM card reader
Ignition sense
Navi™ wheel
Bluetooth interface
RS232 connector
Modem and fax function via RS232 and Bluetooth interface
GSM data transfer:
- HSCSD up to 43.2 kbps
- GPRS up to 40.2 kbps
AT command set
User-guided phone configurations
Memory for 2 user profiles including contacts, voice tags, and personal settings
Contacts download from compatible mobile phone supporting Bluetooth technology
Forwarding of business cards and calendar entries to a compatible phone via either text message or wireless Bluetooth technology
Audio Features
Handsfree with excellent audio quality, option to use compatible existing car loudspeakers
Support fot car radio mute
Switch between compatible headset supporting Bluetooth technology and car audio
Ringing tone and speaker volume adjustment with Navi™ wheel
Switch between normal, silent, and standby modes
Voice Features
User-dependent voice dialing, memory for up to 15 names per user profile
5 user-dependent predefined voice commands per user data set:
- Replay voice memos
- Download contacts
- Replay name tags
- Replay command tags
Call Features
Call initiation:
- Voice dialing with name tags
- From phonebook
- From call registers
- From favorites list
- Number dialing
- Speed dialing
Accept/reject an incoming call
Voice call back to SMS sender
Closed User Group
Fixed Dialing Number
Messaging
Read SMS
Send predefined SMS templates
Interfaces Supported
GSM 900/1800 antenna
Bluetooth profiles:
- Object Push
- Dial-up Networking
- Fax
- Serial Port
- Headset
- Handsfree
RS232 connector
Languages
Bulgarian, Croatian, Czech, Danish, Dutch, English, Estonian, Finnish, French, German, Greek, Hungarian, Icelandic, Italian, Latvian, Lithuanian, Norwegian, Polish, Portuguese, Romanian, Russian, Serbian, Slovak, Slovenian, Spanish, Swedish, Turkish, Ukrainian
Sales Package Contents
Radio Unit TFE-4R
Display Unit XDW-1R
Handset HSU-4
Mounting Plate MKE-1
Microphone HFM-8
External HF Speaker SP-2
Power Cable PCU-4
Data Cable AD-3
Installation and User's guides
Radio Unit TFE-4R
Weight: 305 g
Dimensions: 140mm x 106mm x 41mm
Operating voltage: approximately 10.8V-16V, normally 12V
Power consumption: Active (call) < 1.5A; Standby < 300mA, Off < 1mA
Normal operating temperature: -10° C to +55° C
Intermittent operating temperature: -30° C to +80° C
Storage temperature: -30° C to +80° C
Terran
beurk!
Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
Why... I know its not out yet but it will have a blue tooth / rs232 interface with GPRS etc....
It would certainly enhance the Carpc in a simular way to the Fairlady interface is going to do.
Terran
Another example of this sort of interface can be found in the VDO Dayton Sat Nav systems which interface and control compatible Nokia phones - ie text msgs - calls etc....
Terran
Why not use something more "sexy"...
Camera phone
Bluetooth™ wireless technology
You can keep it in you pant...and use it from the pc via Bluetooth.
Also for internet acces, e-mail...
I know you can do that but you could hide the other... also if in the case me you may not be able to use technology like that where you work.
The 810 could be one with the system... ( Very Matrix reloaded ) how ever I do agree with you.
Personally I like to have both a carphone and mobile - plus the added advantage is if you have a car phone tied in it could be part of the carPC security system..... along with the GPS... Not sure how yet but thats phase two for me ( if its even possible ).
Terran
Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
Better than winamp. Click here for qcd player.
Do any of these phones with GPRS connect to a computer with plain old RS232 for those speeds or is blue tooth the only option.
I have yet to find a bluetooth device that works flawlessly. Also dont want to have to rely on a bluetooth device. Serial is more widepsread and in embedded devices.
I just want to send AT commands and get high speed data.
Doesnt help having a Sony laptop and Sony Erricson phone that dont talk to each other over bluetooh. Incompatible![]()
Yeh - if you read on above you'll notice the 810 does have RS232 - thats why I posted it here....Originally posted by thenominous
Terran
There's plenty of phone with rs232 option...
You could buy a cheap Siemens on ebay hardwire it to you rs232. And use it with your PC for data or phone through AT cmd
