Page 5 of 5 FirstFirst 12345
Results 41 to 44 of 44
Thread: 4am MUSIC Console 1.5 (music jukebox)
  1. #41
    Jun 2003
    Quote Originally Posted by KFEdaddy2k
    I found the 4am programs a coulpe days ago and I love them. Simple interface, yet it's visually pleasing and has a bit of a "Wow, cool screen dude" look to it.
    One problem i'm havign is the Media Console will shut down after about five minutes of inactivity. If I have a movie playing, stop the movie after 10 minutes or so, there's no media console loaded, not even minimized.
    Anything I can do to remedy that? If so, my $25 is on it's way. Perfect software otherwise.
    Thanks,
    Kurt
    Hi Kurt,
    Glad to hear your experience with 4am product suite has gone so well, hope you will continue to enjoy the future releases as well.
    I think the reason you are noticing 4am Media Console shut down after 5 mins of inactivity is actually because the trial version of 4am Media Console is limited to 10 mins of use for each run. To make sure this is what is happening just load up 4am Media Console and check to see if it is shutting down exactly 10 minutes later, if so then there is no problem, expect that it isn't registered. If you feel it is anything else please do let me know, and I will look into it further (although I have yet to hear of any problems with it shutting down after x mins of inactivity).
    Thanks for your support and praise of the products it is greatly appreciated.
    Overnight Technologies
  2. #42
    Aug 2003
    That sound about right. I have only been running it for a few days, so I have not had the chance to get a stopwatch out and time it when it shuts down, but I'll take your word on that. I didn't read anything about a trial shutting down after 10 minutes, but then again, as with most tech guys, I don't read much of the manual that comes with stuff. My bad.
    Thanks for the reply, you'll see my registration and $25 this afternoon.
    Kurt
  3. #43
    Aug 2003
    Detroit what!
    Im trying to get Music Console to run properly on my widescreen laptop. (1280x768) MEDIA console scales just fine but no matter what I do in music console (resize to fit full screen checked or not) it cuts off the bottom of the screen. Any ideas?
    When will the new Music console be out?
  4. #44
    Jun 2003
    Quote Originally Posted by ShaneMcFarland
    Shane this shouldn't be happening in 4am Music Console if you use the correct skin. Make sure you are using skin: brightness169-1280\
    You can set this in the setup program under the General Settings tab, the skin is designed to work with 1280x720 (16x9) though, this will leave 48 empty pixels at the bottom (btw: if you use the brightness169-1280 skin and set the fullscreen option on then you'll have a black bar the bottom which will also cover the taskbar, this may be better than just letting whatever is underneath peak through). Unfortunately there are no default skins with a 3:2 resolution.
    Hope that helps let me know if there are more problems.
