Results 1 to 2 of 2
Thread: Select which audio codec XVID/DIVX files use? ffdshow?
    Variable Bitrate m2x0p9x's Avatar
    May 2002
    Modesto, CA
    I was having a problem with Centrafuse not playing the audio on a DVD. So I installed AC3 Filter in hopes on getting audio back but no luck, AC3 Filter doesn't work with the modded audio drivers i'm using. So I installed ffdshow and got my audio back for DVD's. Awesome.
    Next, the audio when playing XVID/DIVX files is really low, and because AC3 Filter doesn't work i'm at a loss. Is there anyway to tell XVID/DIVX files to use the ffdshow codec for the audio? I am able to raise the volume using ffdshow.
    May 2002
    Modesto, CA
    Well after some searching I found an application to select your default codecs for pretty much all media types. It also lets you disable the Windows 7 codecs permantly so Windows doesn't make undo the changes.
    It's called Win7 DS Filter Tweaker.
    http://www.codecguide.com/windows7_p...er_tweaker.htm
    In case anyone else needs it.
  1. DIVX/XVID playback with multiaudio using dotnet
    By quacka in forum Coders Corner
    Last Post: 08-18-2008, 06:25 AM
  2. DivX/Xvid playback
    By null_byte in forum Newbie
    Last Post: 04-12-2006, 02:12 PM
  3. DiVX (XviD) encoding question
    By Lando in forum Software & Software Development
    Last Post: 02-16-2005, 03:59 PM
  4. Better Divx,Xvid ETC... Codec
    By CoolDaddyAndy in forum Software & Software Development
    Last Post: 10-27-2003, 11:09 PM
