Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Car PC Software
  1. #11
  2. #12
    Nov 2012
    Brisbane, Australia
    Hey bambam, if you don't know the basics of programming, then seeing a complete source code project will just go straight over your head. Especially my code as it has no commented lines to explain anything and I do lots of shortcuts and low level stuff which can easily freeze the whole computer up if not used correctly, you know lovely things like memory stomping :$ Not for the faint hearted.
    It's a very steep learning curve and it's not for everyone. You best bet is first learn the basics from tutorials until you grasp an understanding of how everything works, otherwise it will be like reading chinese...
    VB6 is a great language to start off with, as it's not so in-your-face as .net is, and it still allows you to do some 'oop' type programming.
    FreeIce i believe is open source? if you are after an example of code, though i am sure none of it will make sense to you. :P
  3. #13
    Dec 2011
    Here's the Maps class:
    Code:
    Option Explicit
    Dim ma As Object
    Dim view_X As Double, view_Y As Double, view_Z As Double
    Dim dView_X As Double, dView_Y As Double, dView_Z As Double
    Dim aim_view_z As Double
    Dim fade As Single
    Dim fade_rate As Single
    Private Const default_fade_rate = 0.2
    Private Const Min_Zoom = 4
    Private Const Max_Zoom = 21
    Private Const aim_view_step = 0.1
    Private Const Dynamic_Map_Sizing = True
    Private Const menuSizeX = 300
    Private Const menuSizeY = 170
    Private Const menuSizeShortY = 90
    Private Const border = 10
    Private Const inner_border = 15
    Private Const title_border = border + inner_border
    Dim map_cache As New dictionary
    Private Const pi = 3.14159265358979
    Private Const r = 6378.1
    Private Const mercRatioX As Double = 6.38011715438025E-03
    Private Const mercRatioY As Double = 6.38532710916024E-03
    Private Const scrollborder = 10
    Dim snap_location As Boolean, snap_zoom As Boolean
    Private Type mappos
        X As Double
        Y As Double
        zoom As Double
    End Type
    Private Type sRECT
        Left As Single
        Top As Single
        Right As Single
        Bottom As Single
    End Type
    Private Const text_height = 35
    Private Const icon_size = 32
    Private Const car_glow = "jpg/carlight.jpg"
    Private Const car_icon = "jpg/caricon.jpg"
    Private Const default_car_fade_rate = 4
    Dim car_fade_rate As Long
    Dim car_fade_stage As Long
    Private Const back_arrow = "jpg/backarrow.jpg"
    Private Const back_arrow_size = 60
    Private Const back_border_x = 20
    Private Const back_border_y = 30
    Dim themeDarkR As Long, themeDarkG As Long, themeDarkB As Long
    Dim themeR As Long, themeG As Long, themeB As Long
    Dim clicked As Boolean, clickX As Single, clickY As Single
    Dim menuShowTimeout As Long, menuShowTimeout_rate As Long
    Private Const menuShowTimeout_Max = 500
    Private Const menuShowTimeout_MinShow = 50
    Dim settings As Object
    Private Const zoom_panel_x = 206
    Private Const zoom_panel_y = 70
    Dim cGrammar As New Collection
    Dim lastMove As Integer
    Public Property Get icon() As String
        icon = "jpg/maps-320.jpg"
    End Property
    Public Property Get caption() As String
        caption = "Maps"
    End Property
    Public Property Get ClassName() As String
        ClassName = "CarPC.Maps"
    End Property
    Sub Class_Load()
        Set settings = CreateObject("CarPC.Settings")
        settings.loadfile TypeName(Me)
        Set ma = CreateObject("CarPC.MapAid")
        ma.Init
        If Val(settings.var("GPS_Enabled")) = 1 Then
            ma.connectGPS Val(settings.var("GPS_Port")), Val(settings.var("GPS_Baud"))
        End If
        themeDarkR = Val(settings.var("themeDarkR"))
        themeDarkG = Val(settings.var("themeDarkG"))
        themeDarkB = Val(settings.var("themeDarkB"))
        themeR = Val(settings.var("themeR"))
        themeG = Val(settings.var("themeG"))
        themeB = Val(settings.var("themeB"))
        view_X = Val(settings.var("longitude"))
        view_Y = Val(settings.var("latitude"))
        view_Z = Val(settings.var("zoom"))
        cGrammar.Add "Locate"
        cGrammar.Add "Zoom in"
        cGrammar.Add "Zoom out"
        cGrammar.Add "Pan left"
        cGrammar.Add "Pan right"
        cGrammar.Add "Pan up"
        cGrammar.Add "Pan down"
        cGrammar.Add "More"
        cGrammar.Add "Max"
        cGrammar.Add "Menu"
    End Sub
    Public Property Get grammar() As Collection
        Set grammar = cGrammar
    End Property
    Sub Class_KeyDown(windows As Object, keycode As Integer)
        If keycode = 27 Or keycode = 8 Then
            windows.moveClassDown Me
            settings.savefile
        End If
        If keycode = 189 Then
            dView_Z = dView_Z - 0.05
            snap_zoom = False
        End If
        If keycode = 187 Then
            dView_Z = dView_Z + 0.05
            snap_zoom = False
        End If
        If keycode = 37 Then
            dView_X = dView_X - 10
            snap_location = False
        End If
        If keycode = 39 Then
            dView_X = dView_X + 10
        End If
        If keycode = 38 Then
            dView_Y = dView_Y + 10
        End If
        If keycode = 40 Then
            dView_Y = dView_Y - 10
        End If
        If keycode = 13 Then
            snap_location = True
            snap_zoom = True
            If Not ma.gpsEnabled Then
                End If
            End If
            menuShowTimeout_rate = 2
        End If
    End Sub
    Sub Class_blt(windows As Object, graphics As Object)
        If windows.getLeadingWindow Is Me Then
            fade_rate = default_fade_rate
        Else
            fade_rate = -default_fade_rate
        End If
        fade = fade + fade_rate
        If fade < 0 Then fade = 0
        If fade > 1 Then fade = 1
        If fade > 0 Then
            If ma.satelites >= 3 And snap_location Then
                view_X = ma.longitude
                view_Y = ma.latitude
            End If
            If ma.satelites >= 7 And snap_zoom Then
                If ma.speed > 150 Then
                    aim_view_z = 13
                ElseIf ma.speed > 100 And ma.speed < 140 Then
                    aim_view_z = 14
                ElseIf ma.speed > 70 And ma.speed < 90 Then
                    aim_view_z = 15
                ElseIf ma.speed > 40 And ma.speed < 60 Then
                    aim_view_z = 16
                ElseIf ma.speed < 30 And ma.speed > 10 Then
                    aim_view_z = 17
                Else
                    aim_view_z = 15
                End If
            Else
                aim_view_z = 0
            End If
            If dView_X <> 0 Or dView_Y <> 0 Then
                Dim pt As mappos
                pt.X = view_X
                pt.Y = view_Y
                pt.zoom = view_Z
                pt = radialToPixel(pt)
                pt.X = pt.X + dView_X
                pt.Y = pt.Y + dView_Y
                pt = pixelToRadial(pt)
                view_X = pt.X
                view_Y = pt.Y
            End If
            If dView_Z <> 0 Then view_Z = view_Z + dView_Z
            dView_X = dView_X * 0.92
            dView_Y = dView_Y * 0.92
            dView_Z = dView_Z * 0.92
            If Abs(dView_X) < 0.001 Then dView_X = 0
            If Abs(dView_Y) < 0.001 Then dView_Y = 0
            If Abs(dView_Z) < 0.001 Then dView_Z = 0
            If aim_view_z > 0 Then
                If aim_view_z > view_Z Then
                    view_Z = view_Z + aim_view_step
                End If
                If aim_view_z < view_Z Then
                    view_Z = view_Z - aim_view_step
                End If
                If Abs(aim_view_z - view_Z) < aim_view_step Then view_Z = aim_view_z
            End If
            If view_Z > Max_Zoom Then view_Z = Max_Zoom
            If view_Z < Min_Zoom Then view_Z = Min_Zoom
            Dim use_zoom As Long
            use_zoom = floor(view_Z)
            Dim rendered As Boolean, insufficient_map_data As Boolean
            Do Until rendered Or use_zoom < Min_Zoom
                Dim render_width As Double, render_height As Double
                render_width = graphics.resX * (2 ^ view_Z / 2 ^ (use_zoom))
                render_height = graphics.resY * (2 ^ view_Z / 2 ^ (use_zoom))
                Dim px As mappos
                px.X = view_X
                px.Y = view_Y
                px.zoom = use_zoom
                px = radialToPixel(px)
                Dim phase As mappos
                phase.X = px.X
                phase.Y = px.Y
                px.X = Round(px.X / ma.store_width) * ma.store_width
                px.Y = Round(px.Y / ma.store_height) * ma.store_height
                phase.X = (phase.X - px.X) / ma.store_width * graphics.resX
                phase.Y = (phase.Y - px.Y) / ma.store_height * graphics.resY
                Dim maps(0 To 3) As mappos, map_path(0 To 3) As String
                maps(0).X = px.X - ma.store_width / 2
                maps(0).Y = px.Y + ma.store_height / 2
                maps(1).X = px.X + ma.store_width / 2
                maps(1).Y = px.Y + ma.store_height / 2
                maps(2).X = px.X - ma.store_width / 2
                maps(2).Y = px.Y - ma.store_height / 2
                maps(3).X = px.X + ma.store_width / 2
                maps(3).Y = px.Y - ma.store_height / 2
                Dim i As Long
                Dim drawPoints(0 To 3) As sRECT
                drawPoints(0).Left = graphics.resX / 2 - phase.X - graphics.resX
                drawPoints(0).Top = graphics.resY / 2 + phase.Y - graphics.resY
                drawPoints(0).Right = graphics.resX / 2 - phase.X + graphics.resX - graphics.resX
                drawPoints(0).Bottom = graphics.resY / 2 + phase.Y + graphics.resY - graphics.resY
                drawPoints(1).Left = graphics.resX / 2 - phase.X
                drawPoints(1).Top = graphics.resY / 2 + phase.Y - graphics.resY
                drawPoints(1).Right = graphics.resX / 2 - phase.X + graphics.resX
                drawPoints(1).Bottom = graphics.resY / 2 + phase.Y + graphics.resY - graphics.resY
                drawPoints(2).Left = graphics.resX / 2 - phase.X - graphics.resX
                drawPoints(2).Top = graphics.resY / 2 + phase.Y
                drawPoints(2).Right = graphics.resX / 2 - phase.X + graphics.resX - graphics.resX
                drawPoints(2).Bottom = graphics.resY / 2 + phase.Y + graphics.resY
                drawPoints(3).Left = graphics.resX / 2 - phase.X
                drawPoints(3).Top = graphics.resY / 2 + phase.Y
                drawPoints(3).Right = graphics.resX / 2 - phase.X + graphics.resX
                drawPoints(3).Bottom = graphics.resY / 2 + phase.Y + graphics.resY
                insufficient_map_data = False
                Dim mC As String
                For i = 0 To 3
                    maps(i).zoom = use_zoom
                    maps(i) = pixelToRadial(maps(i))
                    mC = map_cache.Item(maps(i).X & "," & maps(i).Y & "," & use_zoom)
                    If mC <> "" Then
                        map_path(i) = mC
                    Else
                        map_path(i) = ma.getMap(maps(i).X, maps(i).Y, use_zoom)
                    End If
                    drawPoints(i).Top = (drawPoints(i).Top - graphics.resY / 2) / 2 ^ use_zoom * 2 ^ view_Z + graphics.resY / 2
                    drawPoints(i).Bottom = (drawPoints(i).Bottom - graphics.resY / 2) / 2 ^ use_zoom * 2 ^ view_Z + graphics.resY / 2
                    drawPoints(i).Left = (drawPoints(i).Left - graphics.resX / 2) / 2 ^ use_zoom * 2 ^ view_Z + graphics.resX / 2
                    drawPoints(i).Right = (drawPoints(i).Right - graphics.resX / 2) / 2 ^ use_zoom * 2 ^ view_Z + graphics.resX / 2
                    If map_path(i) = "" Then
                        insufficient_map_data = True
                    Else
                        map_cache.Item(maps(i).X & "," & maps(i).Y & "," & use_zoom) = map_path(i)
                    End If
                Next
                insufficient_map_data = insufficient_map_data And Dynamic_Map_Sizing
                If Not insufficient_map_data Then
                    rendered = True
                    For i = 0 To 3
                        graphics.BitBlt map_path(i), drawPoints(i).Left, drawPoints(i).Top, drawPoints(i).Right, drawPoints(i).Bottom, fade * 255, fade * 255, fade * 255
                    Next
                Else
                    use_zoom = use_zoom - 1
                End If
            Loop
            If ma.satelites >= 3 Then
                Dim iconLocation As mappos
                Dim mapLocation As mappos
                iconLocation.X = ma.longitude
                iconLocation.Y = ma.latitude
                iconLocation.zoom = view_Z
                mapLocation.X = view_X
                mapLocation.Y = view_Y
                mapLocation.zoom = view_Z
                iconLocation = radialToPixel(iconLocation)
                mapLocation = radialToPixel(mapLocation)
                graphics.BitBlt car_glow, graphics.resX / 2 + (-mapLocation.X + iconLocation.X) * graphics.resX / ma.store_width - icon_size, _
                                          graphics.resY / 2 + (mapLocation.Y - iconLocation.Y) * graphics.resY / ma.store_height - icon_size, _
                                          graphics.resX / 2 + (-mapLocation.X + iconLocation.X) * graphics.resX / ma.store_width + icon_size, _
                                          graphics.resY / 2 + (mapLocation.Y - iconLocation.Y) * graphics.resY / ma.store_height + icon_size, _
                                          themeR * car_fade_stage / 255, themeG * car_fade_stage / 255, themeB * car_fade_stage / 255
                graphics.BitBlt car_icon, graphics.resX / 2 + (-mapLocation.X + iconLocation.X) * graphics.resX / ma.store_width - icon_size / 2, _
                                          graphics.resY / 2 + (mapLocation.Y - iconLocation.Y) * graphics.resY / ma.store_height - icon_size / 2, _
                                          graphics.resX / 2 + (-mapLocation.X + iconLocation.X) * graphics.resX / ma.store_width + icon_size / 2, _
                                          graphics.resY / 2 + (mapLocation.Y - iconLocation.Y) * graphics.resY / ma.store_height + icon_size / 2, _
                                          255, 255, 255
                car_fade_stage = car_fade_stage + car_fade_rate
                If car_fade_stage <= 0 Then
                    car_fade_stage = 0
                    car_fade_rate = default_car_fade_rate
                ElseIf car_fade_stage >= 255 Then
                    car_fade_stage = 255
                    car_fade_rate = -default_car_fade_rate
                End If
            End If
            Dim y_phase As Single, y_fade As Single
            menuShowTimeout = menuShowTimeout + menuShowTimeout_rate
            If menuShowTimeout >= menuShowTimeout_Max Then
                menuShowTimeout_rate = -2
            ElseIf menuShowTimeout <= 0 Then
                menuShowTimeout_rate = 0
            End If
            y_phase = menuShowTimeout / menuShowTimeout_MinShow
            If y_phase > 1 Then y_phase = 1
            y_fade = y_phase
            y_phase = graphics.resY * (1 - y_phase)
            Dim back_button_phase As Long
            If (windows.input_type And 2) Or (windows.input_type And 8) Then
                back_button_phase = back_arrow_size + border
            End If
                graphics.BitBlt "jpg/maps-menu-short.jpg", border, border + border - y_phase, border + menuSizeX, menuSizeShortY + border - y_phase, themeR, themeG, themeB
                    graphics.BitBlt back_arrow, back_border_x, back_border_y - y_phase, back_border_x + back_arrow_size, back_border_y + back_arrow_size - y_phase, themeR, themeG, themeB
                End If
                graphics.bltText "No GPS Detected", back_border_x + border + back_button_phase, back_border_y - y_phase + back_arrow_size + border - text_height * 2, back_border_x - 2 * border + menuSizeX, back_border_y - y_phase + back_arrow_size + border - text_height, vbAlignLeft, themeR, themeG, themeB
            ElseIf ma.satelites = 0 Then
                End If
                graphics.bltText "No GPS Signal", back_border_x + border + back_button_phase, back_border_y - y_phase + back_arrow_size + border - text_height * 2, back_border_x - 2 * border + menuSizeX, back_border_y - y_phase + back_arrow_size + border - text_height, vbAlignLeft, themeR, themeG, themeB
            Else
                graphics.BitBlt "jpg/maps-menu.jpg", border, border + border - y_phase, border + menuSizeX, menuSizeY + border - y_phase, themeR, themeG, themeB
                End If
                graphics.bltText "Longitude: ", back_border_x + border, back_border_y - y_phase + back_arrow_size + border, back_border_x - 2 * border + menuSizeX, back_border_y - y_phase + back_arrow_size + border + text_height, vbAlignLeft, themeR, themeG, themeB
                graphics.bltText "Latitude: ", back_border_x + border, back_border_y - y_phase + back_arrow_size + border + text_height, back_border_x - 2 * border + menuSizeX, back_border_y - y_phase + back_arrow_size + border + text_height * 2, vbAlignLeft, themeR, themeG, themeB
                graphics.bltText "" & formatDegree(ma.longitude), back_border_x + border, back_border_y - y_phase + back_arrow_size + border, back_border_x - 2 * border + menuSizeX, back_border_y - y_phase + back_arrow_size + border + text_height, vbAlignRight, themeR, themeG, themeB
                graphics.bltText "" & formatDegree(ma.latitude), back_border_x + border, back_border_y - y_phase + back_arrow_size + border + text_height, back_border_x - 2 * border + menuSizeX, back_border_y - y_phase + back_arrow_size + border + text_height * 2, vbAlignRight, themeR, themeG, themeB
                graphics.bltText "Speed: ", back_border_x + border + back_button_phase, back_border_y - y_phase + back_arrow_size + border - text_height, back_border_x - 2 * border + menuSizeX, back_border_y - y_phase + back_arrow_size + border + text_height * 0, vbAlignLeft, themeR, themeG, themeB
                graphics.bltText "" & Round(ma.speed) & " kph", back_border_x + border + back_arrow_size + border, back_border_y - y_phase + back_arrow_size + border - text_height, back_border_x - 2 * border + menuSizeX, back_border_y - y_phase + back_arrow_size + border + text_height * 0, vbAlignRight, themeR, themeG, themeB
                graphics.bltText "Satelites: ", back_border_x + border + back_button_phase, back_border_y - y_phase + back_arrow_size + border - text_height * 2, back_border_x - 2 * border + menuSizeX, back_border_y - y_phase + back_arrow_size + border - text_height, vbAlignLeft, themeR, themeG, themeB
                graphics.bltText "" & ma.satelites, back_border_x + border + back_arrow_size + border, back_border_y - y_phase + back_arrow_size + border - text_height * 2, back_border_x - 2 * border + menuSizeX, back_border_y - y_phase + back_arrow_size + border - text_height, vbAlignRight, themeR, themeG, themeB
            End If
                graphics.BitBlt "jpg/zoom.jpg", graphics.resX - zoom_panel_x - border - border, border + border - y_phase, graphics.resX - border - border, zoom_panel_y + border + border - y_phase, themeR, themeG, themeB
            End If
            graphics.BitBlt "jpg/map-scroll-up.jpg", 0, 0, graphics.resX, scrollborder, themeR * y_fade, themeG * y_fade, themeB * y_fade
            graphics.BitBlt "jpg/map-scroll-down.jpg", 0, graphics.resY - scrollborder, graphics.resX, graphics.resY, themeR * y_fade, themeG * y_fade, themeB * y_fade
            graphics.BitBlt "jpg/map-scroll-left.jpg", 0, 0, scrollborder, graphics.resY, themeR * y_fade, themeG * y_fade, themeB * y_fade
            graphics.BitBlt "jpg/map-scroll-right.jpg", graphics.resX - scrollborder, 0, graphics.resX, graphics.resY, themeR * y_fade, themeG * y_fade, themeB * y_fade
            If clicked Then
                If distance(back_border_x + back_arrow_size / 2, back_border_y + back_arrow_size / 2, graphics.resX * clickX, graphics.resY * clickY) < back_arrow_size / 2 Then
                    Class_KeyDown windows, 27
                End If
                If distance(graphics.resX - zoom_panel_x + back_arrow_size / 2 - border - 3 + 132, border * 2 + 5 - y_phase + back_arrow_size / 2, graphics.resX * clickX, graphics.resY * clickY) < back_arrow_size / 2 Then
                    Class_KeyDown windows, 13
                End If
                If distance(graphics.resX - zoom_panel_x + back_arrow_size / 2 - border - 3 + 66, border * 2 + 5 - y_phase + back_arrow_size / 2, graphics.resX * clickX, graphics.resY * clickY) < back_arrow_size / 2 Then
                    Class_KeyDown windows, 189
                End If
                If distance(graphics.resX - zoom_panel_x + back_arrow_size / 2 - border - 3, border * 2 + 5 - y_phase + back_arrow_size / 2, graphics.resX * clickX, graphics.resY * clickY) < back_arrow_size / 2 Then
                    Class_KeyDown windows, 187
                End If
                If graphics.resX * clickX <= scrollborder Then
                    Class_KeyDown windows, 37
                End If
                If graphics.resY * clickY <= scrollborder Then
                    Class_KeyDown windows, 38
                End If
                If graphics.resX * clickX >= graphics.resX - scrollborder Then
                    Class_KeyDown windows, 39
                End If
                If graphics.resY * clickY >= graphics.resY - scrollborder Then
                    Class_KeyDown windows, 40
                End If
                clickX = 0
                clickY = 0
                clicked = False
            End If
        End If
        settings.var("longitude") = view_X
        settings.var("latitude") = view_Y
        settings.var("zoom") = view_Z
    End Sub
    Private Function distance(x1 As Single, y1 As Single, x2 As Single, y2 As Single) As Single
        distance = Sqr((x2 - x1) * (x2 - x1) + (y2 - y1) * (y2 - y1))
    End Function
    Private Function floor(v As Double) As Double
        floor = Round(v - 0.49)
    End Function
    Private Function radialToPixel(pos As mappos) As mappos
        radialToPixel.X = ((pos.X - 85) / 180 * pi) * r * (2 ^ pos.zoom) * mercRatioX
        radialToPixel.Y = r * Log(((1 + Sin(pos.Y / 180 * pi)) / Cos(pos.Y / 180 * pi))) * (2 ^ pos.zoom) * mercRatioY
        radialToPixel.zoom = pos.zoom
    End Function
    Private Function pixelToRadial(pos As mappos) As mappos
        pixelToRadial.X = (pos.X / mercRatioX) / (2 ^ pos.zoom) / r * 180 / pi + 85
        pixelToRadial.Y = (2 * Atn(Exp(pos.Y / r / (2 ^ pos.zoom) / mercRatioY)) - pi / 2) * 180 / pi
        pixelToRadial.zoom = pos.zoom
    End Function
    Sub Class_Click(windows As Object, X As Single, Y As Single)
        clickX = X
        clickY = Y
        clicked = True
    End Sub
    Sub Class_Speak(windows As Object, phrase As String)
        If phrase = "Locate" Then
            lastMove = 0
        ElseIf phrase = "Menu" Then
            Class_KeyDown windows, 8
            lastMove = 0
        ElseIf phrase = "Zoom in" Then
            lastMove = 187
        ElseIf phrase = "Zoom out" Then
            lastMove = 189
        ElseIf phrase = "Pan left" Then
            lastMove = 37
        ElseIf phrase = "Pan right" Then
            lastMove = 39
        ElseIf phrase = "Pan up" Then
            lastMove = 38
        ElseIf phrase = "Pan down" Then
            lastMove = 40
        ElseIf phrase = "More" Then
            If lastMove > 0 Then Class_KeyDown windows, lastMove
        ElseIf phrase = "Max" Then
            If lastMove = 187 Then
                dView_Z = dView_Z + 1
                snap_zoom = False
            ElseIf lastMove = 189 Then
                dView_Z = dView_Z - 1
                snap_zoom = False
            End If
        End If
    End Sub
    It's designed to be simple enough that anyone can program classes for it, with classes being able to be completely independent (they can even exist in separate executables) with event calls for various user input such as touchscreen, keyboard and speech with Class_Click, Class_KeyDown and Class_Speak plus a blt call for painting refreshes.
  1. Replies: 3
    Last Post: 07-20-2007, 02:33 PM
  2. What gps software do most of you use?
    By Bboy_jon in forum Centrafuse
    Last Post: 07-07-2006, 03:43 AM
  3. Software Only?
    By guest in forum StreetDeck
    Last Post: 05-25-2006, 10:06 PM
  4. Software Bundle question...which software bundle are u useing?
    By ecswookie in forum Software & Software Development
    Last Post: 02-28-2006, 02:47 PM
  5. which dvd software do you use in mc ?
    By Thinboy in forum MediaCar
    Last Post: 08-12-2004, 10:28 AM
