Results 1 to 3 of 3
Thread: Remote Wake CarPC?
    May 2010
    Herákleion, Iraklion, Greece, Greece
    Remote Wake CarPC?
    I was wandering. is there a way , to start a pc remotely in the car?
    i'm corrently doing so, by using the car alarm aux outpout, but its limited to the 1 mile or so (max for car alarms)
    Wake on Lan would work well, but only problem is you dont have an internet connection in the car >_>
    I was thinking , if a broadband modem would work, but then again, this has to have the computer running, to be connected...
    sending a message to a pager and then having it control some relays??? i'm talking about any scenario...
    The reason i want to do it, is becouse, if you can remote start your pc from distance, you could do many thinks, like ,
    1) if the car alarm pager sends you a message, you could open the pc, and via a i.p camera, see if there is an actual thread
    2)Remote start the car ofc.
    3)have the computer do a sequance of tasks, when woken that way (again to protect from thiefs)
    and whatever some one could think!
    Apr 2012
    Radelaide South Aus
    Hi
    Google will be your best bet..there are a few mobile phone solutions which allow you to control device's via txt message ect
    http://www.mobileactivator.com/shop/
    http://www.apogeekits.com/remote_con...cell_phone.htm
    http://www.elektor.com/products/kits...e.703254.lynkx
    Mar 2005
    NY
    This is not a software hack, as much as a hardware one. It depends on how much money you had and your experience with coding. If you can;t afford the prefabbed solution, you need to go the embedded route.
    Easiest for the new programmers, if you have an arduino, and a sim card shield, and a relay, you can easily do a remote start by sending a text message. you can also use an old smart phone if you know android or WM or ios programming and tap into the serial connection for the switch (sending a 2 second HIGH pulse on the TX line, which i think can be achieved by just turning serial on).
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
  1. Remote accessing PC to CarPC
    By Driven1 in forum Wireless Communications
    Last Post: 02-05-2009, 01:36 PM
  2. Car Alarm Remote Carpc turn on
    By guizai in forum General MP3Car Discussion
    Last Post: 02-14-2007, 10:57 PM
  3. Replies: 0
    Last Post: 05-30-2006, 11:29 PM
  4. Laptop powerup by wake on ring or wake on lan
    By ZeroDefects in forum Power Supplies
    Last Post: 08-25-2005, 10:01 AM
  5. Using a Pocket PC for IR remote for CARPC
    By NightHunter in forum Software & Software Development
    Last Post: 02-26-2004, 03:30 PM
