Would Franson GpsGate do what you want? I've been running that on 64Bit Win7 and Win8.
I'm looking for some freeware 64-bit serial / com port splitting software (I can find 32-bit no probs, but the 64-bit is hard to come by, it seems). I want to split my USB GPS com port between FreeICE and Sygic fleet at the same time....
Can anyone help?
2013 Ultima Can Am - Can I fit it with a CarPC?
MP3Car PC build worklog here
Facebook full car build here
GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
I have put xport in my dropbox, don't worry its free software and works on 64Bit
https://www.dropbox.com/s/rw7s1i86kwjp7xb/xport1.52.zip
just extract all files straight onto C:/xport (make new folder)
then start xport.exe and once setup you can close it (will go to tray) and it will autostart on system boot
I use it to split my gps signal for sygic and riderunner
View my worklog here
Thanks folks, I knew it was worth a post! I've downloaded both and will see which works best..... I want to have whichever I use to run at startup (ideally as a service), before the FE kicks in. Cheers!
np problem , if you have questions about xport don't hesitate to pm me
Is this the same Xport from the Curios tech website?
http://www.curioustech.net/xport.html
The site stats that it is 32-bit only and the download I had would not install on my machine with the 64-bit OS
2002 Chevrolet Avalanche
Zotac NForce 610i ITX, 2GB RAM, 2.6 GHz Intel Pentium Dual Core CPU, 320 GB Hard Drive, 12' VGA touchscreen monitor, 3D mouse
My Worklog : http://www.mp3car.com/vbulletin/work...avalanche.html
Yea Xport itself runs on a 64bit platform but the virtual com port sharing will not work with x64. I use xport to relay data to minicam on my W7 x64 carpc.
I use GPSGate to share the GPS receiver to 2 virtual com ports. One for xport and the other for centrafuse. This software is free as well.
