Results 1 to 4 of 4
Thread: Relationship Between two Hex strings...
    Jun 2013
    Question Relationship Between two Hex strings...
    Hi All!
    I'm trying to make a .NET based application for ELM327 trouble code scanning device. Most of my app code is done. however, I am stuck at one point. And I need someone to help me decode two hex strings to find a relationship between them.
    I have logged some communication between ECU and a trouble code scanner for carrying out car's fuel pressure test. However there is one message (that is sent from the user side) that keeps on changing each time which is dependent upon the last message received from the ECU which is also varying every time.
    I'm posting different responses from logged data for carrying out fuel pressure test at different times.
    Code:
    RECEIVED (07E8)			     SEND (07E0)
    05 67 03 0C 17 6A 00 00	     05 27 04 8F 45 37 00 00
    05 67 03 0C DB 68 00 00	     05 27 04 B0 70 6B 00 00
    05 67 03 10 3B 87 00 00	     05 27 04 3B BC 10 00 00
    05 67 03 12 CC E7 00 00	     05 27 04 5A 50 5B 00 00
    05 67 03 13 A4 88 00 00	     05 27 04 34 E7 63 00 00
    05 67 03 15 D9 CB 00 00	     05 27 04 5D 76 7D 00 00
    05 67 03 1A 2F 05 00 00	     05 27 04 57 81 33 00 00
    05 67 03 1B 45 AE 00 00	     05 27 04 E8 10 E7 00 00
    05 67 03 29 BC B3 00 00	     05 27 04 85 65 10 00 00
    05 67 03 31 09 97 00 00	     05 27 04 E1 FB A6 00 00
    05 67 03 32 C5 6B 00 00	     05 27 04 D1 EC 83 00 00
    05 67 03 33 1E 9E 00 00	     05 27 04 7A A4 AF 00 00
    05 67 03 3A F6 2F 00 00	     05 27 04 71 26 98 00 00
    05 67 03 3B 75 AB 00 00	     05 27 04 E9 76 0C 00 00
    05 67 03 3E 50 51 00 00	     05 27 04 59 2B 67 00 00
    05 67 03 3F D9 94 00 00	     05 27 04 91 2B D3 00 00
    05 67 03 42 58 A9 00 00	     05 27 04 19 E7 CB 00 00
    05 67 03 43 F9 A0 00 00	     05 27 04 55 81 ED 00 00
    05 67 03 48 82 DD 00 00	     05 27 04 F3 2D 41 00 00
    05 67 03 4E 25 DE 00 00	     05 27 04 DE F2 99 00 00
    05 67 03 51 40 DE 00 00	     05 27 04 DB B6 DF 00 00
    as it can be seen 3 bytes are always changing with each test, both, in the message received from the ECU, and the one sent back to the ECU from the diagnostic scanner. Can anyone help me trying to figure out relationship between these two strings?
    P.S: The messages under RECEIVED column come in reply to a command "02 27 03". currently I've stored about 70 logs in a database. my program keeps on sending the command "02 27 03" until it gets a reply that I already have in the database. In that case the fuel pressure test starts successfully. but it often takes hours because there exist more than 16 million combinations for 3 byte data...
    May 2012
    Grandville, MI
    To help you we need to know what kind of vehicle and the year.
    If it is new enough to be ODBII the commands are pretty standard and should help you out dramatically.
    If you have an odbii vehicle then you can search for ODBII codes pretty easily.
    Jun 2013
    Quote Originally Posted by redheadedrod View Post
    thanks for the quick reply. well sorry my bad I should have mentioned the vehicle. its Land Rover Defender model 2007 (11 bit CAN)
    Jun 2013
    and yes indeed it is OBD-II Standard vehicle...
  1. RR Strings Variables
    By ssteger in forum VaultWiki
    Last Post: 10-21-2009, 03:33 PM
  2. RR Strings/Variables Plugin [ Now in RRExtended ]
    By Blue ZX3 in forum RR Plugins No Longer Supported
    Last Post: 03-27-2009, 12:59 AM
  3. Relationship between ODB and CanBus
    By Cruizer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-04-2006, 12:45 AM
  4. relationship advice
    By nappyjim in forum Off Topic
    Last Post: 07-18-2005, 05:58 AM
  5. tried strings in new LCDisplayer?
    By davesaudio2 in forum Software & Software Development
    Last Post: 10-18-2002, 11:42 AM
Tags for this Thread
