Results 1 to 10 of 10
Thread: Voice control software, what one?
    Mar 2003
    UK
    As I don’t have a touch screen and using a touch pad will be a pain at high speeds what would be the best voice control software out there that would do the job?
    I have tryed Realize Voice 4.0 with not much luck
    Jun 2003
    I've been writing this into my own software to try get as close to 100% voice control as possible with a little bit of Ir for backup, currently have pretty much all media playing commands supporting voice, all your albums can be played with 'play <artist> <album>' which then also adds 'play <track>' voice commands for the album.
    Have been adding mapping/navigation system so today I decided to add voice street directory support, have only done a few quick tests (because it takes approximately 2.5 hours to compile the ~32,000 streets in my city into a speech engine but after thats been done once for each map loads speech data in about 10 seconds), only added 'find <street> <suburb>' so far but it seems to be working pretty good, the downside with having so many possible matches is it decreases the accuracy, the more words in a phrase and the less phrases to match against the more accurate it is.
    Anything dictation based is pretty much useless with todays technology, the only real way to get close to 100% is supply it with a list of known commands to match against instead of trying to turn spoken words into what could be any text.
    Mar 2003
    UK
    Sounds good
    But what could I use for now?
    Variable Bitrate Banderon's Avatar
    Sep 2003
    NJ
    Yeah, I'm also wondering what can be used. I'm thinking about creating a custom interface (geared for what I would like it to do.. but I'd release it to the public if it actually works). I've had experience with working with VB, and C++.. .and I'm gonna try to write this mofo in C#. I'd like to do as little work as possible, of course ... so if there's already a good program out there that can accept voice inputs, that'd be great. So what progs would people recommend?
    My vision: A button on the steering wheel, that you hold down and give the command "load playlist <name of list>" and simple commands such as "fast forward 10 seconds" etc. Windows has voice recognition built in, but I think it'd be easier to just have voice software that'd do it for me, rather than try to code in their API into my attempt. Any ideas are welcome.
    Maximum Bitrate Seraph's Avatar
    Jun 2003
    Elmhurst, Illinois
    Guys,
    The next version of aiPC (should be released tomorrow) will have full feature voice control. Play, pause, next, visualisation etc as well as time, etc.
    I was using homeseer (home automation software) but I found something a lot smaller. Voiceflux (www.voiceflux.net) it's very easy to configure and very easy to program. Voice command, TTS in one package and it's less than one meg. you do need to install SAPI5.
    Check out voiceflux.
    L
    - Lwin M. Maung
    If it's stuck, force it. If it breaks it needed replacing anyway
    Sep 2003
    NJ
    It's a fun program to play around with, but unfortunately it doesn't have an option to type out what you say, only a predetermined setting. So I can get everything up to "computer, load M P 3" but I'd have to have the mp3's name pre-scripted. I can't just say the name of the MP3 and have it typed into the Open dialogue. I guess I'll have to figure out on my own how this damn SAPI stuff works. Oy, it's been like half a decade since I've done any programing... =\
    Maximum Bitrate PTCruiser's Avatar
    Oct 2002
    Switzerland
    Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
    Oct 2002
    Switzerland
    EDIT:
    www.voiceflux.net is using MS speech & reco & truevoice.
    This programm can be use as grider:
    You say mp3 and it simulate a key. So it's like using the keyboard!
    So you can just turn EVERY program Ainet,mediacruiser, mediaengine with speech reco in a few second!
    Will go this way!
    THX!
    Jun 2003
    Elmhurst, Illinois
    Yepp. Some people at myHTPC went that way with grider and voiceflux. I am sending keystrokes from voiceflux to aiPC for my project.
    - Lwin M. Maung
    Sep 2003
    NJ
    True, you can send individual keystrokes... but that's kinda tedious. Plus, I'm not always exactly sure on the precise spelling of some of the mp3s right off the bat. VoiceFlux is great... I just wish one of the actions it had was a "Dictate for x seconds" one, where for x amount of seconds it would just type out whatever you said.
    I downloaded the MS SDK, and realized just how much I'd forgotten about programing. =P I can make the front-end GUI and make it interactive, but I'll have to relearn a lot to make the program work with the hardware and to incorporate the speech recognition.
