Results 1 to 10 of 12
Thread: DCDC Software Integration
    Dec 2007
    NY
    Has anyone incorporated the DCDC usb info in their software from their provided sdk http://www.mini-box.com/DCDC-USB? I would like to import the battery voltage into my app. If anyone has, can you show me the coding please? I use autoit and I have limited and poor understanding about dll calls.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Should be easy enough if the SDK is any good.
    RR and CF plugins should be easy as there is sample code.
    Doing it with AutoIT should also be possible as it it close to VB.
    Do you not use a recognised FE?
    Dec 2007
    NY
    No, I use something I created. You're right that autoit is similar to VB now that I think of it. What is the smallest program I can download that will allow me to read VB programming so I can see their VB examples and try to translate them?
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by Champak View Post
    Do you have a source code that can command your DCDC_USB ?
    May 2008
    Bordeaux, France
    Quote Originally Posted by Enforcer View Post
    Check the link in the first post
    Ho, yes , the VB example is very easy to use !!!!
    May 2008
    Bordeaux, France
    Is that Sarcasm?
    No, i have done a RR plugin ! Don't tested , but think it' is ok for test !
    Dec 2007
    NY
    So i looked at the vb stuff and would like help please. I cant figure out exactly what I need to transfer over to autoit to just get the battery voltage (Im using MS excel development tool). The two times i used vb stuff, i actually had a helpfile that stated properties and methods for me to do what I needed...not actually deciphering another program.
    Any help would be appreciated.
    May 2008
    Bordeaux, France
    If you want use a .net dll with autoit , see here
  1. RR and GPS software integration
    By rcdash in forum Road Runner
    Last Post: 11-25-2008, 06:09 PM
  2. Integration with external GPS software
    By DeStRoW in forum Road Runner
    Last Post: 09-27-2007, 05:08 PM
  3. Replies: 7
    Last Post: 12-27-2006, 08:01 PM
  4. Replies: 3
    Last Post: 04-21-2006, 05:20 PM
  5. Replies: 3
    Last Post: 04-13-2005, 11:11 AM
