do you have an updated version ?
it doesnt work with current winamp3 version
So here is my first try at skinning in Winamp3. It is based on the Arby skin, but designed to fit a 800x480 resolution screen while showing the usual windows start bar and regular winamp playlist.
Note: This is a Winamp3 skin.
Screenshot
zLance.wal
I don't yet have a car or screen to test this on. If your on XP, the default start bar may be too tall to make everything fit - solution is to switch to the other 2000ish start bar.
Any bugs or enhancements - let me know. This is basically a beta right now. Final release will be free to download.
-Lance
the sun always shine
Thats interesting. The copy of Winamp3 that I use was downloaded a long time ago. So tonight I downloaded it again in case there was some minor update that broke my skin. I find that it is the same build #488 - Feb 25 2003. It still works fine on my machine. I am running it on Windows 2000 SP4. What is your build and OS?
-Lance
I just tested it on XP Pro SP1 with the latest build of winamp3 and it worked fine for me. What error are you getting?
Anyone else seeing this issue?
-Lance
well skin works...
but its off the edge of my screen and cant get it back overwhat do I do?
You will need to locate and open C:\Program Files\Winamp3\studio.xnf
In this file are the settings for every skin you have used. You can either reset the X and Y locations for this skin or just delete all the info for the skin. It will recreate that when you load the skin again.
-Lance
