Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: aiPC is nearly done
    Maximum Bitrate Seraph's Avatar
    Jun 2003
    Elmhurst, Illinois
    aiPC is nearly done
    Well, I re-did the interface again for 800x600 and I am using aiPC.ini file to set the applications and games to load on aiPC so you should be able to point to what ever you want rather than have me predefine the applications. Look at aiPC.ini and you should be able to figure it out pretty quickly.
    Check out the website for updated software. The interface will stay now. Colours may change a little for the beta release. Beta will be released with voiceflux voice command application and should be able to configure that using another ini file as well.
    I am going to modify the 800x600 version to 800x480 for WS format if there are enough requests.
    aiPC website: http://www.stars-gazer.com/~aipc/
    I was told that the site is slow. I am going to call up my web hosts and figure out what's going on tomorrow.
    Lwin
    ps. Moderators: if you think this thread should be combined with the other one, feel free to combine them.
    - Lwin M. Maung
    If it's stuck, force it. If it breaks it needed replacing anyway
    Oct 2002
    Alaska
    looks really good man, except when I add a directory, is it possible for that folders sub directories not to simply be added to a linear list? Instead those sub folders appearing at the top of the list, and we can browse through those as one would in Explorer?
    Also, how about a way to auto load a folder, so you dont have to click "add folder"
    But its looking really good man! Keep it up
    Jun 2003
    Elmhurst, Illinois
    I'll add the autoload folder feature. As for the explorer look, unless I write a flash explorer, it will not be a fun job. Anyone want to take a bite of that and try it out?
    - Lwin M. Maung
    Oct 2002
    Alaska
    what program is this stuff done in?
    Jun 2003
    Elmhurst, Illinois
    AutoPlay Media Studio. Same thing G-Net uses to make their DigitalDash. I think aiPC alpha is only a few things away from DD 2.0 and you get aiPC for free.
    Is the ini file setup useful?
    - Lwin M. Maung
    Oct 2002
    Alaska
    what about language?? do you do any real coding, or does autoplay do all that as well?
    Jun 2003
    Elmhurst, Illinois
    It has a mix of stuff. There is a bit of VB and a flash coding but when you compile and stuff, autoplay takes care of it.
    EDIT: The music player now open up the load folder if there is nothing on the list. If there is something, it will just skip that part and go to the list.
    - Lwin M. Maung
    Apr 2003
    Melbourne/Cranbourne
    cannot seem to download it. When I do its not the complete size that it should be. Only seems to download about 1MB then stops.. Are you able to send it to me, I have MSN and ICQ.
    thanks
    Jun 2003
    Elmhurst, Illinois
    MSN is good. I am lwinmaung@hotmail.com I could be lwin_maung@hotmail.com as well. They are both mine.
    - Lwin M. Maung
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    Any chance of some screenshots? I'd rather know if I like the look of it before I download it.
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
