Results 1 to 9 of 9
Thread: which micro kernel or cut down linux to use?
    Newbie phoTToniq's Avatar
    Mar 2003
    London
    Hi - IRMP3 seems to have everything i need (i.e. character display, keypad input and infra red support) from an mp3 player. I was wondering which version of linux i should use. I want the fastest boot time - should i be looking at a microkernel or a regular install of linux?
    Hope someone can offer advice.
    P.
    Mar 2001
    Atlanta, Georgia
    Im very close to setting up linux for my self, i run Gentoo linux all the time on my desktop machine and i find it the perfect match for anything really, No bloat just what you want. You choose everything to install from the get go and you even have the option to compile everything youself for optomization. And then you could build your own small kernel easily. I would recomend you try Gentoo and on top of that maby COAR(iirc.) which is old but im gona see if i can get it to work from the gentoo base install, it setups everything to run from a ram disk so you get speed and can mount your filesystem read only which should help keep it uncorrupted, however im not sure if this is really nessary in the days of ReiserFS and ext3 etc. Hope that helps some.
    2003 WRB Subaru WRX
    99 Nissan Sentra SE Cobal Blue (SOLD)
    P166 64Meg RAM
    ATI All In Wonder PCI 16Meg
    SB AWE32 Plug'n Play
    Linksys PCI NIC
    Western Digital 13Gig UATA-66 HD
    5.6in Color Active Matrix TFT Screen
    AloneInTheVoid
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    If you slim down your kernel and do your own init scripts you can get a kernel load to userland in about 2-3s after POST completes. Once you are in userland you can immediately start your mp3 processes and background the other startup scripts that are not as critical.
    Kernel load times are really pretty fast when you start tweaking.. and for ultra fast booting there's always LinuxBIOS
    Aug 2003
    mind explaining the linuxbios more?
    Maximum Bitrate SiGmA_X's Avatar
    Jul 2003
    Portland, OR, USA
    Gork, can you explain (Or point me to find it) about making init scripts?
    1993 BMW 325is - 15.2sec
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    do a google search for linuxbios but not every motherboard is supported.
    '98 Explorer Sport
    80% done
    Sep 2003
    Peoria, IL
    Gorks answer to init scripts is correct, but difficult to elaborate. RH, SuSE (debian based), Slackware, Gentoo, Xandros, or true Debian all have little quirks in thier init scripts. Suse may support something that the rest dont. Do a search on starting services in parallel on google and he has a good general way to make your system cut down its boot time. I personally recommend Suse or debian because it is so easy to update and do the kernel recompile/install( I have found that it is a little easier than the rest). Apt get update is another blessing for the debian crowd, but that is for keeping your system updated. If you arent going to keep it updated then any linux distro should do fine.
    NOTE: http://www-106.ibm.com/developerwork...xw16BootFaster this should help
    Carputer:
    MSI K7T turbo limited ed.
    AMD Duron 600
    TM - 701 ( Touchscreen and VGA kits will be added later)
    ATI Rage Fury
    looking at OPUS 150
    512 PC100
    40Gb HD
    SuSE 8.2 Professional
    Jul 2003
    Portland, OR, USA
    Thank you. I personally perfer Debian, and am quite good at making it run.. I am learning how to source-install XFree86, but that is taking longer then it should, mainly due to my lack of a M10000 system with Linux (Its running XP right now )
    Thanks.
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    I've been messing around lately with a hacked version of LEAF (linux embedded application firewall). Nice thing about it is that LEAF loads everything into an initrd (variable size), so everything can run from a ramdisk. I've also manged to get IDE, ext2 and sound driver support into the distro, so at the moment it can boot and play mp3s off a read only mounted ext2 partition.
    This's nice 'cause you don't have to shutdown. you can just pull the power and it won't care.
