Sounds real nice....I will give it a whirl. Anyone else have a macro solution to run at system startup?
Printable View
this one can run at startup: http://www.axife.com/axmrec/
btw that's what i call 'easy to use', just 2 buttons ;)
With ez-macros you can make an .exe, from within the program, of your macro then just put it in the startup folder.
I like Workspace Macro Pro, http://www.tethyssolutions.com/macro-automation.htm. It is also available in basic version, Workspace Macro, but with Pro you can edit macros. Also assign hotkeys. You can put macros in startup.
If you like to program. You can automate the mouse click writing your own bot in Visual Basic.
The recording tools are nice but custom writing my own worked better.
If you need some help with it. I would suggest the book: Bot Programming: Intelligent Automation For Windows Applications And Games
For what its worth.
