ya there are a lot of macro recoding apps out there. They'll record everything from movement to clicks and keyboard presses.
download.cnet.com and search macro
not sure which ones are freeware
I want to be able to record a macro or something so that I can do a certian function and save it to a file. then I can just run this file and it will replay thoes mouse clicks to do stuff. any ideas? does this make sense?
'98 Explorer Sport
80% done
Try ezMacros
Easy enough for me to use...![]()
If you're a masochist you can try Girder. Http://www.girder.nl
It's probably one of the most powerfull automation programs out there. It also has an extremely steep learning curve. I use it with my Griffin Powermate to control winamp.
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
I'll admit that Girder is a bit intimidating, but after a couple of hours of reading, and playing with some demos, I had mine up and running.
The beauty is you can assign a button on your remote control (for example) to do a whole series of things...I have one button that starts up the gps program, starts the GPS itself, starts logging positions, and shows the direction page.
NaviVoice does macros![]()
try <a href="http://www.hiddensoft.com/AutoIt/">autoit </a>
Has a scripting engine.
0l33l :
almost did not reconize you with the new Avtar. I will give Navi Voice a shot, so you think it will do what I am looking for? Want to keep it simple too.
Well, with NaviVoice, you'd have to use your voice to activate the macroOriginally Posted by jedi7001
