Page 1 of 7 1234567 LastLast
Results 1 to 10 of 62
Thread: FrodoPlayer: Finally Something for ya'll to play with !
    Jan 2003
    Ruston, LA
    This is a functionality test for you to play with. This is not the frodoplayer
    but it is part of it (at least the underlying code).
    I'm not sure of any dependencies but if you have xp with all the updates
    I think it will work. If not post here and I will include what you need.
    Instructions:
    Unzip to a folder.
    Run DBBuilder.exe to build your database.
    after DB is built exit and run functest.exe
    everything else should be self explanatory.
    if you mess up your db or want to start new, their is a blank db in the
    template folder that you can copy into the main folder. Then you can
    rebuild.
    TEST TEST TEST !!! I need Feedback !!
    http://www.midsouthextrusion.com/kev...nalityTest.zip
    UPDATED: !! Now has directory for the man below
    UPDATE # 2 !!! Now supports Ogg Vorbis.
    Please read Readme.txt for details.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Aug 2003
    frodobaggins i have just tested your software with windows xp with sp1 with all the updates and it works fine by me
    Masterlp
    Maximum Bitrate PTCruiser's Avatar
    Oct 2002
    Switzerland
    build the data base without any problem!
    No bug to report....not a lot to play either for the end user.
    Xp pro uptodate...
    Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
    Maximum Bitrate GingerPrince's Avatar
    Apr 2003
    Leeds, UK
    [QUOTE=frodobaggins]
    [QUOTE]
    Yep, works here (XPSP1).
    One thing, will you have to run DB Builder every time you change your MP3 collection? I can see this becoming somewhat of an annoyance.
    I still prefer browsing a tidy directory structure. My opinion I know, but I think it still counts as feedback
    GingerPrince
    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
    Carputer Install - http://www.stuffandting.com/carputer/
    CarBox Software -- http://www.stuffandting.com/carbox/
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    AWSOME!
    Works perfectly (almost). it detected all folders but said it only scanned 1707 files. I have 2,057 mp3's
    One thing. I'm not the most brilliant developer, but these recursive directory and file search source codes don't seem to find all my sub folders or mp3 - and i have no idea why. Your search engine seemed to find all directories. I was wondering if you would like to share your source code. I would also like to know what you used to get the id3 tag info. I can only find code to get v1 tags and not v2. Any help would be much appreciated .
    We are, will have and forever will be...
    But not tommorrow!
    Oct 2002
    Switzerland
    v2 tag...easy!
    Are you using VB,C++, delphi...?
    Perhaps start a new thread
    Jan 2003
    Ruston, LA
    [QUOTE=GingerPrince][QUOTE=frodobaggins]
    db verification and updating will be built in to the app, if you do update the collection, you will just tell it to update, and it will do it in the background.
    I'm working on an autoupdate schedule.
    Browse by directory is the first thing I implemented, I'm sorry I didn't include it in this test.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jan 2003
    Ruston, LA
    Quote Originally Posted by PTCruiser
    Xp pro uptodate...
    Like I said, just a functionality test....much much more coming
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jan 2003
    Ruston, LA
    Quote Originally Posted by AlienEclipse
    AWSOME!
    hmmmm, interesting. Are you sure all of them are mp3s ? as in *.mp3
    maybe some are mp2 or something. This little prog only gets *.mp3
    Sure I can help with tags
    lemme find the original code
    edit: I can give you the recursive dir code as well
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jul 2003
    SORRY, Major F!!! up on my part. It did detect all files and folders. I hadn't finished copying my collection to a new directory a made over a week ago.
    So again. AWSOME, WORKS BRILLIANTLY. (XP, SPK1, up-to-date as of today)
    But not tommorrow!
