Page 9 of 9 FirstFirst 123456789
Results 81 to 89 of 89
Thread: Alpha Release: XMPC-CAR for XM
  1. #81
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    jbors: Yes. it will probably be linux-only for the time being. SDL_perl is a decent library and thread-safe so it works fine for me. Drawing is done via OpenGL with the text rendering handled by OGLFT and FreeType libraries. I am developing it on top of X but because of SDL, it should work fine in DirectFB also (though I have not yet seen working SDL OpenGL acceleration in DirectFB) I am the guy who has been talking to you off and on regarding the EPIA-M LinuxBIOS issues, btw...
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
  2. #82
    FLAC jbors's Avatar
    Nov 2003
    Yes I know.
    But why do you need OpenGL though ?
    I've seen some efforts to support DRI under DirectFB, so you may need to take a look again.
  3. #83
    May 2004
    When I load the VB project I get an error saying that :
    Threed32.ocx could not be loaded. The program runs fine with out it. Where can I delete the reference to it?
  4. #84
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    To bad
    I just cannot get this nice software to work. I have tried comport 1-9
    2001 S10 ZR2
    Chucks Skin - to old
  5. #85
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Chuck
    To bad
    [SAT RADIO] Alpha 2
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #86
    Nov 2005
    Quote Originally Posted by dhowse
    I rellay like what you are doing. I'm looking at putting together a Carputer and incorporating an XM PCR. My question:
    Is there a converter you can use so that the XM PCR can utilize an existing car antenna? Visibility is everything with XM in the car. Hiding the standard XM PCR antenna in the dash will probably make it unusable.
    Doug
    DOUG,
    check Future Shop or Best Buy. I know Future shop in canada now sells them.
  7. #87
    Jan 2006
    XMPC-CAR for XM modified to fit 640x480 touchscreen...
    I'm know I'm late getting to the XM-PCR party but I just bought one off eBay and installed it on my car computer about a month ago. I then found gork's wonderful app. Thanks to gork's generosity I was able to compile a modified version of his XMPC-Car Tuner to fit my 640x480 touchscreen. The problem was that the signal meters scrolled off the screen so I played around with the formatting in the source code until it fit my touchscreen. Below is a link to my modified .exe and a screenshot. BTW, I use a dark desktop theme on my car computer so the screen won't blind me at night. Also the red and blue font colors blend in perfectly with my Jetta's dash lighting scheme.
    XMPC-CAR.exe modified to fit 640x480 touchscreen
    Some additional XM icons I made
  8. #88
    Jun 2003
    Chicago
    replayreb
    I've been using using Gork's XM app for almost two years now. It's nice to see someone working with the code again. The only problem I have with this app is that it will not resume from hibernation. The app has to be manually closed before the pc is put into hibernation and the app has to be reopened.
    Do you know how to fix this? I think the XM interfaces embeded in Mediaengine and Frodoplayer can resume from hibernation properly.....it would be nice if this app could also.
  9. #89
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    Use Frodo's satellite player x alpha 3.. from what i understand xm pcr and xmd1000 (with modified cables) are compatible so the software should work. i use it with my xmd1000 and it resumes from hibernation perfectly and is very nicely designed..
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
