Page 17 of 20 FirstFirst ... 7891011121314151617181920 LastLast
Results 161 to 170 of 196
Thread: CarBox - First Test Release
  1. #161
    Jan 2003
    Ruston, LA
    Quote Originally Posted by ukchris
    I have written an app that will dim the screen, see here... http://www.mp3car.com/vbulletin/show...074#post165074 I cannot post the file as it is just over the limit, I can mail it to anyone who may be interested though.
    Chris.
    I'll host it.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #162
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Quote Originally Posted by frodobaggins
    I'll host it.
    You have a PM... I need to know how to get it to you... email?
    People should note this should, in theory, only work under Win2k and WinXP, shouldn't do anything bad on another OS, just will not work. If there is any interest I'll make the settings configurable externaly in an INI file or something.
    Chris.
  3. #163
    Jan 2003
    Ruston, LA
    You can download it Here
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #164
    Maximum Bitrate GingerPrince's Avatar
    Apr 2003
    Leeds, UK
    Quote Originally Posted by NightHunter
    This is a Kick *** Feature. The GPS program I am using in the skin pic is routis 2004. I had to update my skin as soon as I seen this.
    Nice to see that feature working with a skin designed to use it. Kinda looks like you've got a Pocket PC embedded into your screen
    Sy
    GingerPrince
    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
    Carputer Install - http://www.stuffandting.com/carputer/
    CarBox Software -- http://www.stuffandting.com/carbox/
  5. #165
    Banned NightHunter's Avatar
    Dec 2003
    Milwaukee, WI
    Quote Originally Posted by GingerPrince
    Sy
    The advantage to using routis. routis is made for to work with a pocket pc as well so, I figured this would work well.
  6. #166
    Nov 2003
    Massachusetts
    Does Routis allow cross-map routing or only within the loaded map?
    Chris.
  7. #167
    Dec 2003
    Milwaukee, WI
    Chris.
    What do you mean, you can load map data for the whole US on your PC.
  8. #168
    Nov 2003
    Massachusetts
    In Destinator on the IPAQ, and I believe the PC is the same, the maps are segmented to save space so you can pick and choose which ones to load (ideal for low capacity devices). You cannot route across maps, for example I drove from Boston to New York which spans two maps, I could not have my IPAW navigate me all the way there because ot spanned two maps, you have to switch maps and reroute.
    I believe Destinator 3 still has this limitation as it was originally designed for the PocketPC. I just wanted to make sure this isn't the case with other packages I consider.
    So in short... of you were of a mind to... you could create a route from Boston to LA using Routis...?
    Chris.
  9. #169
    Apr 2003
    Leeds, UK
    Not totally true. Yes the maps are split on Destinator, so for example the UK is split into 5-6 different maps. You can route to anywhere else in the country though. When you load a map, it loads the minor roads for that area, but still has major roads for the whole country. So eg if I lived northwest UK and wanted to trael somewhere southeast, I'd load southeast map to get exact destination, then it'd take me via major roads (i don't wanna take country back-roads cross country!) and then minor roads to my destination.
    D3 will be better though apparently. They just have to releas the damn software! grrr..
    GingerPrince
  10. #170
    Nov 2003
    Massachusetts
    I suppose the issue I had (with US maps) was that I was trying to get to a street address at the other end which it didn't recognise and hence could not be set as a destination. Probably my refusal to read manuals, but hey, I expect this stuff to be obvious!
    Chris.
