Page 18 of 20 FirstFirst ... 891011121314151617181920 LastLast
Results 171 to 180 of 196
Thread: CarBox - First Test Release
  1. #171
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Sy,
    I can now, in Delphi, dim the screen without Gamm Correction in Delphi. I have done this in Delphi 6 and it will work for any Win2k and WinXP machine. It basically displays a full-screen borderless form over the entire screen, makes it partially transparent using the AlphaBlend. The forms properties are overridden with WS_EX_TRANSPARENT which makes it ignore any mouse clicks, therefore, with it always on top, varying the AlphaBlend effectively dims the screen.
    Would you be interested in integrating this code? It's really only about 5 lines of code and could be a viable alternative when gamma correction doesn't work. I can send you the sample project source if you would like.
    Another option might be if I keep it similar to how it is now but use command line switches then launch it from a button in your app... hmm...
    Chris.
  2. #172
    Maximum Bitrate GingerPrince's Avatar
    Apr 2003
    Leeds, UK
    Quote Originally Posted by ukchris
    Sy,
    Chris.
    good work. if you want to pm me the code i'll e happy to add it to carbox as an option.
    sy
    GingerPrince
    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
    Carputer Install - http://www.stuffandting.com/carputer/
    CarBox Software -- http://www.stuffandting.com/carbox/
  3. #173
    Nov 2003
    Massachusetts
    Is there anything that can be done to help CarBox look a little better on a 600 x 800 screen? I am running in portrait and it hangs off the screen and doesn't fill it vertically.
    Chris.
  4. #174
    Apr 2003
    Leeds, UK
    Chris.
    You have 2 options.
    1. Quick and dirty - edit the skin.ini and change displaywidth to 600 and displayheight to 800. It'll fill your screen but obviously look stretched and warped.
    2. Create your own 3:4 aspect ratio skin.
    Sy
    GingerPrince
  5. #175
    Banned NightHunter's Avatar
    Dec 2003
    Milwaukee, WI
    In Destinator on the IPAQ, and I believe the PC is the same, the maps are segmented to save space so you can pick and choose which ones to load (ideal for low capacity devices). You cannot route across maps, for example I drove from Boston to New York which spans two maps, I could not have my IPAW navigate me all the way there because ot spanned two maps, you have to switch maps and reroute.
    I believe Destinator 3 still has this limitation as it was originally designed for the PocketPC. I just wanted to make sure this isn't the case with other packages I consider.
    So in short... of you were of a mind to... you could create a route from Boston to LA using Routis...?
    Chris.
    I believe so. I am not sure how it would work on an Ipaq but on a laptop or computer. No problem.
  6. #176
    Nov 2003
    Massachusetts
    Sy,
    I seem to get skipping in Destinator voice prompts when MP3's are playing, is this typical when it is a comapritively slow processor? Have you seem this before? I am guessing it is just missing portions of the prompt, like it will miss "turn left" etc.
  7. #177
    Apr 2003
    Leeds, UK
    Sy,
    I think that's just destinator, I've seen other people having a similar problem, when it will just say "yards" for no apparent reason, with nothing to clarify
    GingerPrince
  8. #178
    Nov 2003
    Massachusetts
    Quote Originally Posted by GingerPrince
    I'll try to test more tonight, in particular if it works more cleanly when MP3's are not playing.
  9. #179
    Apr 2003
    Leeds, UK
    CarBox 0.7 is here!
    After what seems like forever, I've now release CarBox 0.7!
    Been a while since my last update, as I've recently started a new job so had to spend my time working
    Anyway, new features in 0.7 include: -
    Album View - This option will let you view your whole directory subtree as one big, sorted list of albums. It searches all your MP3 directories and displays all the "leaf" directories as albums in a list. Try it, you'll soon see what it does. Works best if you arrange your files as \MP3Path\Artist\Album\Song.
    Drill To File - You can now drill right down to files (MP3, AVI etc) rather than just directories, so you can add individual songs etc.
    Progress Box - To make it more obvious that CarBox is busy doing "stuff", there's now a popup that shows progress.
    The skinner and spaceskin aren't 0.7 compatible yet, but they will be shortly.
    Enjoy,
    Sy
    GingerPrince
  10. #180
    Apr 2003
    Leeds, UK
    Sorry, download link was broken - have now fixed this.
    GingerPrince
