INTEL INSIDE
DE-FRAGMENT IT
other than that format and reinstall windows.
hey guys, i gow and old 5+ years HP nothing special says inter inside but that is all w/out stripping it i wanted to free up memory and fragment and delete the old files of the people who gave it to me. so, i ran a fragmenting program and was iratated with the questions offered every 5 seconds compress this, delete that........... so i got ****ed and impatiant and ran it's own auto complete program. 4 hours later my computer won't go now.
problems
computer boots up says hit spacebar to abort mem. check. you do that and it goes ahead anyway
next, it finaly comes to a screed that reeds not enough mem. for windows 95 quit 1 or more applications. press any key to continue. so, i hit ANY key and it flashes with it is now safe to turn on your comp.
any ideas, i'm at a loss and feel dumb any help will be greatly appreciated
Dupe Accounts/Troll
you may be able to install over the current OS so you dont load any of the info...
XtReMoDs.com
Carputer Status (Not installed.)
-VIA M10000 N
-TM-7002S + TSK (7" LCD)
-512MB PC2700 DDR
-40GB 2.5" HD
-SB Live!
-Rand McNally GPS
-DLink FM Tuner
-XMRPC
_
Originally Posted by XtReMaTriX
thanks guys i'll try it
Dupe Accounts/Troll
Sounds like your system is totaly rotted out. The best thing to do would be to wipe the drive, reformat and reinstall. While you can reinstall windows over the old install, you'll probably just run into new problems and inherit the old ones. Back up what you can't afford to lose and reformat.
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
Can I suggest after a rebuild you format it like this...
This way you can keep it less fragmented...
Terran
I suggest you go with gigs instead of percent, but this is probably a really old 1-4gig drive, so keep it all on c if you ever manage to install
True... Its just an artical from my site that... but the thery is that you can restore images on the fly and fragging only happernes on the data area.... problem solved.Originally Posted by jol
Terran
i got a little more help and we're installing windows. thanks a bunch guys.
Dupe Accounts/Troll
never install windows over top of itself unless you plan to format. UPdating system files with updates and patches, then reloading old files over top of new one sis asking for a headache.
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
