Why not linux? Doesn't corrupt the OS when turned off quicker load time just to name a few.
Not everyone does:
http://www.dashpc.com/
Why? Simple. I normally run Linux. On a carpc, I would normally run ME (boots a lot quicker) but 1) my motherboard drivers for ME just suck big time 2) There are no really good GPS applications for Linux and Wine/Linux combo is not too great/stable for my use.
L
- Lwin M. Maung
If it's stuck, force it. If it breaks it needed replacing anyway
There are many gps packages for linux, here are two that I will be trying out to decide if i want win2k or linux onboard.Originally Posted by Seraph
gpsilon - http://gpsmap.sourceforge.net
gpsdrive - http://gpsdrive.kraftvoll.at
aultl
Originally Posted by 2000i30cg
Yepp Windows ME. The quickest Winblows to boot from the time you press the power button. My XP on my espresson gets to the usable screen in about 30-40 seconds. Post time is around 10 seconds. On WinME on the same system, I get to usable screen in about 20 seconds. 20 Second Boot is pretty good in my book until I decide to pay MS 1000 bucks for the XPe developer kit.
- Lwin M. Maung
Originally Posted by alphonsus
The main problem is that there are no vector based GPS programs that run on linux out there... Any maps must be downloaded in sections
(as images) from maquest in very small areas at a time. And because they are just images, we can't do any navigation, just display a moving map.
Now if there was a linux based GPS/Nav Program that uses the commercial Nav-Tech maps, or could somehow use the map database that comes with one of the commercial map programs out there (mappoint, delorme streets & atlas), then we would have something great to use!!
Does this already exsist?
aultl:
Neither of those listed support route planning.
You should probably give a windows gps solution a shot before making your decision. I would recommend trying a friend CoPilot 2003 or live 7. If your primary reason for in car computing is gps nav, you'll settle for nothing less.
