Yes if you have ODBII or Ibus on the car. Otherwise, you have to use relays.
is there any (relatively simple) way to control some things in the car with a pc. such as the a/c or radio/cd. How about lock/unlock etc.. I just thought it would be more convenient that way to have all the controls on one touch screen.![]()
- Lwin M. Maung
If it's stuck, force it. If it breaks it needed replacing anyway
I thought OBDII is only connected to engine ECU![]()
Nope ODBII also have connections to your door, window control etc as well. So you can unlock/lock your door. Bring your windows up and down as well. You just have to send out the right signal.![]()
- Lwin M. Maung
Hmm ok thanks...I guess I didnt see the parts where it say you can control alot of car electronics through OBDII. I dont have one thats probably why I never bother to look deeper into it.![]()
