Results 1 to 10 of 13
Thread: WIN XP Remote Desktop no password?
    Variable Bitrate Mikesz's Avatar
    Apr 2001
    I want to be able to log into my remote car computer with remote desktop on my main computer but dont want the car computer to stop or require a password at the login screen when starting up. Anybody know how to accomplish this?
    mike
    91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
    Variable Bitrate craigyb's Avatar
    Sep 2003
    UK, Sale, Cheshire
    run
    control userpasswords2
    unclick/check require passwd bit and then add a passwd for the user that needs t login.
    It worked for me
    Craig
    Audi S8 supercar
    Modded Xbox 400GB HD
    Rear 7" screen & navplus
    Toyota Hiace Van
    Shuttle PIII 866 256Mb 10GB OPUS powered
    MediaCar & Mappoint 2004
    Custom fit 7" TFT VGA TSK
    Mar 2007
    Did this work as I can't get it to. I probaly require a complete nebie how to on it. Do I run the userpasswords on the carpc or the one I'm acceesing it from?
    currently the carpc boots without password but I cannot acces remotely because I'm asked for username and password, which if I don't type anything it still doesn't work???
    Dec 2006
    Iowa
    goto to start > run > gpedit.msc
    windows settings > security settings > security options > Accounts: limit local accounts use of blank password to console logon only > check disable.
    Had to do the same thing to be able to login with admin account with no password.
    Mar 2007
    Quote Originally Posted by jaw4322 View Post
    Is this on the lappy in the car or the PC at home which I want to control the lappy with?
    I'm assuming home PC, will try it..
    Right, Win 2K, I get this far - windows settings > security settings > then the only security options are in a sub folder under "Local Policys". If I D click that folder I get a list of policys starting with "Additional restrictions for anonymous connections" and ending with "insigned non-driver installation behavoir"
    I'm afraid I don't see "limit local accounts use of blank password to console logon only " anywhere
    What am I doing wrong?
    \v/
    \v/
    Newbie Samon's Avatar
    Apr 2006
    Melbourne, Victoria, Australia
    Hi NobbyV4,
    craigyb was correct... but I'll go through it in a little more detail for you. Quite a few of the steps that I've described are just double-checks, but it's probably worth going through them jujst to be safe.
    Firstly, on your carputer (I'm assuming windows XP), set a password for the user (Control Panel > User Accounts > Create a Password).
    Next, click Start > Run and type "control userpasswords2" (with out the quotes) and click OK.
    Now, click on the user that you are using, then un-tick the "Users must enter a user name and password to use this computer". Click OK.
    You will be prompted to enter the password, enter the same one (twice) that you just entered in the user accounts section above, then click OK.
    Open Power Options (Control Panel >Power Options) and select the Advanced tab. Ensure that the "Prompt for password when computer resumes from standby" option is NOT ticked. Click OK.
    Open the Display Properties (Control Panel > Display), and select the Screen Saver tab. Ensure that the "On resume, display Welcome screen" (or "On resume, password protect" depending on your settings) is NOT ticked. Click OK.
    Once you have rebooted the carputer, it should automatically log in as if there was no password. When connecting to the carputer remotely, you will need to use the password that you specified earlier.
    Good luck!
    Samon.
    Mar 2007
    Thanks for that, I look forward to giving that a go when I get back home
    \v/
    Mar 2007
    Samon, your a star, worked perfectly. Thanks very much
    \v/
    Apr 2006
    No Probs!
    Glad to be of help.
    Samon.
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    Quote Originally Posted by Samon View Post
    Hi NobbyV4,
    Good luck!
    Samon.
    The problem with this method is that when you get back to the carputer after a remote session you need to put in a password at that point. The other method (allowing RD with no password) will allow you to just click enter on the logon screen.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
  1. are there similar xp media player desktop
    By inniss777 in forum Software & Software Development
    Last Post: 11-05-2003, 05:43 PM
  2. Win XP Hibernation and USB Mass Storage
    By leenas in forum Software & Software Development
    Last Post: 10-28-2003, 06:34 PM
  3. interlaced desktop in xp?
    By fujikawa23 in forum LCD/Display
    Last Post: 06-23-2003, 11:21 PM
  4. desktop icon text shaddows & color in xp
    By ShinkunoNamida in forum General MP3Car Discussion
    Last Post: 01-30-2003, 02:33 AM
  5. Win XP and Trident 9685 + Winamp plugins..
    By cyrofilho in forum Software & Software Development
    Last Post: 07-18-2002, 02:47 AM
