Results 1 to 9 of 9
Thread: WMP or Winamp?
    Maximum Bitrate Seraph's Avatar
    Jun 2003
    Elmhurst, Illinois
    WMP or Winamp?
    I know I can easily do WMP controls. Thanks to DeadWeasel, I checked out winamp5 and I am impressed. I have not used winamp since ver 1.92. I am thinking of using winamp as my media modules for Video and Audio players.
    The question is this: I can easily do WMP controls in VB. Where can I find info on winamp? I'll take the one that is easier to do.
    L
    - Lwin M. Maung
    If it's stuck, force it. If it breaks it needed replacing anyway
    Jun 2002
    TN
    Quote Originally Posted by Seraph
    L
    I program in VC++, so things are a little different, but here is a link Winamp SDK. I am not sure if Winamp5 uses the same IPC calls, but it should be something similar. Personally i have to recommend Winamp, the flexibility with all of the Skins, Visuals, and overall better sound quality make it work it to me. And it does not require people to install WMP9. I know there is a VB module that has all of the IPC calls built in, and you just do function calls. It was in the MediaEngine source at one point...
    P.S. And I have a name now, so I will send you some information about My program soon.
    Quincy
    Jun 2003
    Elmhurst, Illinois
    Thanks Quincy.
    - Lwin M. Maung
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Thanks Quincy.
    Better yet Seraph, I could send you both the Clever.exe and the WinampCOM plugin that I use to control WA from VB if you like. It seems to work perfectly with 5 as well! W00t!
    The WinampCOM plugin will provide a direct pipeline between VB and Winamp, and will give you a Winamp object within VB to play with. For example, to make Winamp play the currently loaded file, pop the Winamp.Play method.
    To load another file it's as simple as Winamp.AddFile. Of course, you may or may not want to Winamp.ClearPlaylist first.
    See what I mean? This thing rules!!!
    BTW, I use Clever.exe as a shell-addressed app, because sadly, the WinampCOM plugin is missing the NEXT and PREVIOUS capabilities! Not sure why that is, but as of the latest version, it has not been added. However, the most recent version of it (which I have here), has just added the ability to "read" Winamp's current repeat and shuffle status.
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Jun 2003
    Elmhurst, Illinois
    Sure. Plese send them to my email: lmaung@stars-gazer.com
    - Lwin M. Maung
    Jun 2002
    TN
    I think you might want to stay away from having to call a lot of shell commands. This might be somewhat slower than the Direct IPC calls. all of the above features are easy to implement, you just might have to look up the SendMessage command for the Winamp command that you need to implement. It was fairly easy for me to do. Let me know if you need any help.
    Quincy
    Nov 2003
    Detroit MI
    Quote Originally Posted by qjones
    Quincy
    Well hey hey! This is something that I was attempting to explore, but I simply couldn't find anything in the SendMessage subset that would allow for control of the track forward/back functions. That's about all I use the shell program for, but I have to admit that it is just a *tiny* bit slower than it would be otherwise. Please do share any ideas you may have about this!
    The ALEXIS Project
    Color Coding :
    Jun 2003
    Elmhurst, Illinois
    Sendmessage API is amazing. Well many APIs are.
    http://www.mentalis.org/apilist/SendMessage.shtml
    - Lwin M. Maung
    Nov 2003
    Detroit MI
    Well, THAT API command certainly seems like it has a ton of possibilities, but what I'm talking about are the SendMessage command set found within WinampCOM. Check out the Object Browser to see what I'm talking about. There are the standard methods (play, pause, stop etc), and some of the properties (pause and shuffle states), but the deeper stuff that is usually triggered via mouseclick (show EQ, playlist etc) is done via direct SendMessage commands. I have yet to take advantage of those, especially now since Winamp5 auto-pops the windows I'm concerned with (video).
    Anyhow, since MY machine seems to be able to handle my ghetto method of getting around the missing COM commands, I shall continue to use it until I learn how to do it better. Heh.
    The ALEXIS Project
    Color Coding :
  1. Need help with winamp
    By dikke in forum Software & Software Development
    Last Post: 12-04-2002, 03:01 AM
  2. Interesting Thing With WMP and VB
    By Bj in forum Software & Software Development
    Last Post: 10-08-2002, 02:10 PM
  3. C++ or JAVA for controlling winamp? (long)
    By MikeHunt79 in forum Software & Software Development
    Last Post: 06-05-2002, 07:51 PM
  4. WinAmp 3
    By Rob in forum Software & Software Development
    Last Post: 01-26-2002, 09:00 AM
  5. Slow playlist load at winamp startup
    By xa0s in forum Software & Software Development
    Last Post: 08-18-2000, 11:16 AM
