da_teach, i'm doing a system for my Cabriolet and i need your sourcecode, because i'm doing an interface for activate when i would. It's possible that you give me your sourcecode?
Renault Megane Coupé Cabriolet
P3 550 mhz 256 mb RAM 15 gb hd, dvd.
gps handsfree parrot ck3300
windows xp sp2
road runner
map monkey and viamichelin mapsonic
Touchscreen 7" fully motorized in-dash
Alright guys im feeling a little dumb here but today i tried installing this service and i could not get it to work. I run the InstallUtil.exe and it opens up for about 2 secs then closes before i can enter anything. I know im probably going about this all wrong so if someone could clear this up for me id appreciate it tia.
actually i start and stop the service.
Fuguaa it's because you have not configured the config file. Try tu change the com port
windows xp sp2
road runner
Ride: 2004 Nissan Murano SL AWD/Sheer Silver/Black Leather/factory HIDs.
MoPuter: Transflectivized Lilli 7", EPIA M-10000, 512Mb RAM, 160Gb WD, SBLive!, 54g WLAN, Holux GM-213, 160W M2-ATX PSU
To all that didnt get this to work, make sure you dont have any "spaces" in your filepath (ie, dont place it on the desktop as it is in c:\documents and settings\...).
I moved it to c:\ampctrl and suddenly, it worked... (You must reinstall the program at the new location afaik)
hi what is DTR?
I know this is an old thread, but I'm trying to get it to work so I don't have to listen to my hard drive spool up.
The ampctrl service works great, DTR voltage swings -11.2v to +11.2v from off to on, and the signal will switch on ONE of my 3 amps. I have an automotive relay switching +12v to my amp REM inputs -- works great but DTR can't power it. I tried an 800 mA NPN transistor to switch the relay but it doesn't work. I measured the resistance across the emitter/collector as well as the output voltage with the service on and off and they don't change.
Does anybody have this kind of setup (with the transistor) or just a good explanation sans electronics skematics? I'm not an EE, they make no sense to me.
I am having trouble getting this installed.
Can someone step me thru it?
Thanx,
Ron
