Salvi,you've got a Pm.
Is there anyone else who can help me get this working?
When i run InstallUtil it closes instantly so i can't enter the command line.....
I spent 9 hours on this yesterday and got nowhere,i'm totally stumped.
If anyone needs helps with this, send me a PM. I've done it many times and it's pretty simple.
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
To anyone creating software......
If your gonna post your work don't assume that the bits you leave out of the instructions are irrelevant.............DOS...........that went out with the Ark but it's assumed i will understand how to navigate to a given folder in that poxy black screen........and all you put is "when you get to that folder type this" well thats a great help.
Why don't you try googling "How to navigate using the Command Prompt" or something similar to solve your problem?
A manual can be infinitely detailed. You've got to stop somewhere.
I think using the DTR signal is a great idea and I wanted to give some input:
1) If you search carefully, you should be able to find a 5v reed relay with a high coil resistance. I had one with 1050 Ohms and it works driven directly by the DTR line. This dropped the DTR line on my carputer from 7V to about 5.8V. These are typically low-current contacts, which is perfect for the remote lines. Plus, the remote line is still isolated from the PC. Simple is better.
2) Serial ports go crazy as Windows intitializes them. This might make the amps flip on and off right as windows is coming up. Windows could be intitializing the sound card around this time, too. I am going to try a simple RC lowpass on the signal going to the relay coil so that it takes like 1s for it to switch.
3) Some have commented that they can't use the software featured in this thread because they use the serial port for something else. In this case you are even better off than those with free serial ports because you don't have to install the software and you can still use DTR. It doesn't matter what software is using the serial port. If it is being used, you should get a DTR signal after that software initializes. You just need to make sure that software starts at windows start up (and not "on-demand" later). The only difficulty is the wiring.
4) To prevent turn-off thump, I am powering my amplifier remote lines through switched ignition. That is, IGN --> reed relay --> REM. My computer shuts itself down when ignition goes down, but the amps will already be off.
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
Of course, most serial ports can not drive a relay directly. I actually modified a reed relay to make it more sensitive so it would work for this application (A 1k coil with a proximity-type reed switch). It worked for the most part but would occassionally stick "ON" until I tapped it with my finger. Oh well. I ended up using a single transistor circuit to drive the relay from the DTR pin. It includes some low-pass filtering. I packaged it together in a box that does the power moding for the PC.
