Page 3 of 25 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 249
Thread: Windows Service that raises DTR on powerup
  1. #21
    Jan 2004
    Kentucky
    sorry bout that... My webserver host decided to delete my entire account back in the first part of Feb. and I didnt think about this.. This time I uploaded it.. Here to stay unless the admin kills it
  2. #22
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    If im reading this correctly, you are saying you can attach the post marked collector directly to a 12 volt source? is that right? Then attach the base post to the number 4 wire from your serial port and attach the emitter post to the relay switch on the amp. Once the package is installed in Winxp, and the services start up, it should turn on the amp? Did I get that correct? I ask because I have that thump in my system as well and would really like to get rid of it. Are the posts on the transistor marked which is which or is there a color code involved?
    Thanks,
    peter
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
  3. #23
    Jan 2004
    Kentucky
    I listed it as a 2N2222 commonly available at just about any RadioShack... But!... I am gonna actually work on something a little more power tollerant.. You can try this for very little $$... should actually be less than a buck... but it would be alot better if you had a opto-isolator between the Transistor and Carputer... and also I am gonna look for a cheap source for a more suitable Transistor.. I still have not gotten to test this myself as I have not had the time..
    I will soon if no one else does since i have a few hundred General purpose 2222 transistors....
    but you pretty much hit the nail on the head...
    **EDIT** Thinking about it.. It would be more practical and safer for the equipment to use the transistor to trip a relay rated at around 1amp.. although the above should work fine I think I might go with a relay design...
    I will make a diagram unless someone beats me to it later tonight when I get home..
  4. #24
    FLAC chut's Avatar
    Jul 2003
    Hi!
    what happened with this? Were you able to get rid of the "thumps"? I'm gonna go get the parts I need this week and give it a try. I just needed to build a workbench to work on and got that done this weekend.
    Peter
    Quote Originally Posted by Twizted
  5. #25
    Jan 2004
    Quote Originally Posted by chut
    Hi!
    Peter
    I connected the serial port directly to the amp's remote, and it still works very good... :-) No "thumps" at all..
  6. #26
    FLAC chut's Avatar
    Jul 2003
    Do you have a transisitor in there somewhere or are you connecting directly between your serial port and the remote turn on for the amps?
    Quote Originally Posted by burnout.no
  7. #27
    Jan 2004
    No transistor, directly connected.. Atleast, it works for me!
  8. #28
    FLAC chut's Avatar
    Jul 2003
    That's good to know, I finally mounted my pc in the trunk last night. I'll be giving this serial rig a try this weekend.
    Take Care,
    Peter
  9. #29
    Jan 2004
    Yes, go ahead and try it!
    Good luck!
  10. #30
    Feb 2004
    Quote Originally Posted by Da_Teach
    After a bit of testing, I found out that directly wiring the DTR to the AMP works, but sometimes fails... So I'll have to put 'something' between the AMP and the serial port... So give easy idea's
    How about:
    regards
    Jim
    [Edit]
    Totally missed the 2nd page of the post , (oops) anyway just using a transistor isn't really going to provide much protection to either the transistor or the serial port, the above schematic is better.
