That's weird.. I'm also using the Nehimiah board.. It puts out like 12.2v.. :/
Stop Buying New Music CD's.
Hit The RIAA where it lives.
Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
I haven't tried it on the machine in the car yet....We'll see about that this weekend, but it's a fence building weekend, so probably not.
So how did you build this cable? Can i take a serial cable that i might have kicking around and cut one end off...then which wire goes to the amp? Can this work for 2 amps off the same serial port? tnx
DTROriginally Posted by ryguy
Yes, provided you want them both to switch on at the same time. Tie the remote switch on lines together and to DTR (preferably through an NPN transistor as above - emitter-follower should work just fine).Originally Posted by ryguy
Ok...i'm trying to follow you here...so i need a "DTR" cable? is that correct?tnx
Err, nope. DTR is one of the pins on the serial port. Stands for Data Terminal Ready. Search for stuff on serial ports. It will tell you all about it, and what pin it is.Originally Posted by ryguy
perfectthanks bud
Also I'm using my only serial port for my ir remote...would this work off a usb to serial adaptor or something like that?
tnx
You guys ever solve this one? So are you saying the Visa M10K puts a constant 12V out through the DTR as soon as power is supplied?Originally Posted by burnout.no
nope, i tried this on my desktop at work and got the above mentioned results...I haven't tried this on my carpc yet.
