Page 7 of 25 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 249
Thread: Windows Service that raises DTR on powerup
  1. #61
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by JasonWW
    I'm not sure I remember this thread so well, but I'll jump in here.
    You could wire in a NC momentary switch inline from the PSU trigger to the mobo. Just push the button when you crank the car and the signal will not get sent to the mobo. Would that fix your problem?
    Not entirely. Theoretically, your suggestion would prevent the computer from booting when starting the car; however, when I turned the car off, it would boot up...sure, you could just press the button again, but I'd rather have this work without any intervention. Does that make sense?
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  2. #62
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    How would it turn on if the car is off? Maybe with your setup but with mine it waits for accessory to turn on. Also whats the big deal anyway it comes on you back your car out of the driveway or whatever and park again it prob almost gets done booting and then when you power off it hibernates again.
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
  3. #63
    Jun 2005
    Kent, England
    does this work with hibernate?
  4. #64
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by mbkowns
    Well, the M1-ATX just sends a signal to the mobo on/off. It doesn't actually know the status of the ignition, just knows that there is a change. So if you skip the "on" signal with the method described above, turning the ignition "off" will send another signal to the mobo on/off- now, since the pc was off, this will trigger it to turn on. The hardoff delay on my PSU will cutoff 45 seconds later, in effect yanking power from the pc = verrrry bad
    500+ full albums
    4,000+ video games
    old carPC
  5. #65
    Mar 2004
    SOCAL
    I see what your saying that would be bad. But if you had the switch disabling the accesory wire it wouldn't turn on when you turn the car on. Just leave the switch how it is until your ready to turn the car on again. If your worried about how the m1 controlls it with the accessory wire then just wire the switch up to your PW-SW on your motherboard.... A switch is really all you need.
  6. #66
    Mar 2004
    SOCAL
    Quote Originally Posted by GreenBeast
    It certainly will works perfect!
    Hibernate starts where you left off last time so when the hibernate file is loaded and your in windows its up and going!
  7. #67
    Jun 2005
    Kent, England
    excellent, just what i wanted to hear
  8. #68
    FLAC djmickyg's Avatar
    Feb 2004
    im having some trubble with the trasistor..
    i got the black plastic half circle type not the metal can, its still a 2n222a but..
    i cant get it to work
    if i hook it up the way explained in the early post i get 4.5 v out the emitter
    with 12V in the collector and the serial port in the base which puts out 5-6v
    should there be this much of a voltage drop?
    EDIT: this is the pins i used
  9. #69
    Oct 2005
    Hou. TX
    Hopefully someone can help with your traNsistor, but I don't remember much about them. Sorry.
    I would have gone old school and just used an automotive relay. The 2 circuits stay seperated that way and your sure to get 12v to the amp.
  10. #70
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by djmickyg
    Emitter is always a diode drop lower than the base when using a transistor in emitter-follower configuration like this. However, most serial ports swing -12v to +12v. It sounds like your serial port doesn't quite manage this, so you don't get the full voltage from the emitter follower. You'll be needing a better transistor circuit design. I'm thinking PNP open collector and flip the DTR line.
