Page 8 of 25 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 249
Thread: Windows Service that raises DTR on powerup
  1. #71
    FLAC djmickyg's Avatar
    Feb 2004
    Quote Originally Posted by Rob Withey
    I'm thinking PNP open collector and flip the DTR line.
    what does it mean by flipping the dtr line?
  2. #72
    Feb 2004
    can i use my 12v ignition wire as the base and then seral port at the collector..
    if u say the emitter is a diode drop lower than the baese then it should come out as 11.5v?
  3. #73
    Jan 2006
    i wasnt looking for a solution as i havnt installed my carpc yet but saw this and tried it. seems to work very well thankyou. Also works with hibernation no problem. i wired it straight off the pin to amp that requires a 12v remote on.
  4. #74
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by djmickyg
    I meant inverting.
    Nope. Go read how transistors work, you want your control signal at the base, that is what it is for.
  5. #75
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Wow, this worked great for me - I'm using a usb-serial converter, with the DTR wire triggering my amp. Finally I have a way to power the amp without EVER hearing thump - standby, hibernate, full-shutdown. Thanks a lot DaTeach!
  6. #76
    Feb 2004
    Quote Originally Posted by Hark
    did u connect it straight to the amp from pin 4??
  7. #77
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    I can say I hooked up the serial cable right up to the amp remote line and it works. I have changed it though and I have it now so it goes through a relay. That if the the Accessory is on then it jumps the relay to enable DTR from the serial port to go to the amps but if the accessory is off it cuts that.
    DTR will ditch the startup speaker pop by itself but I was also having a turn off speaker pop so that fixed that and its perfect now.
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
  8. #78
    Feb 2004
    dam why wouldnt it work for me directly in
    i was only geting 6V out the dtr line.. grr
    doesnt mater i dont have the car anymore so nowhere to put the pc
  9. #79
    Mar 2004
    SOCAL
    Some amps can't handle the lower voltage maybe yours had a problem or maybe you shorted it slightly. Your problem would of been easily fixed with a relay that was triggered by the DTR and kicked on 12v from the accessory to the amp.
  10. #80
    Dec 2005
    Testing DTR circuit...is this correct?
    I'm testing this on my laptop to make sure it works before I tear into my car stereo wiring. Can somebody confirm that how I'm testing it and what I'm seeing in my testing is correct?
    I installed the AmpCtrl.exe service and configured it to work on port 3...my USB port. I plugged this USB-Serial converter into my USB port. When I turn on the computer, I connect my multimeter to pins 4 and 5 of the male-terminated serial cable like this:
    The multimeter shows a constant 9.06V. Just before the Windows boot screen appears, it swings between -1V and -4V for a second or two...then back to a constant 9.06V. Is this about what I should expect?
