Page 9 of 25 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 249
Thread: Windows Service that raises DTR on powerup
  1. #81
    Jan 2006
    well mine gave me -11.98 before the service started then 11.98 when it turned on but thats on my atx mobo and it turns my amp on perfectly connected directly to pin 4 so i think only way your gonna tell is if you hook your amp up and see if it turns it on. may be a problem if your just getting 9 and ur amp needs 12v remote on?
  2. #82
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    I thought you were supposed to use pins 4 & 7 when measuring voltage - maybe it doesn't matter if it's 7 or 5? I got 12V on my Thinkpad T30.
  3. #83
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    Most power supply I have seen here have a RMT pin, which is used for powering the amp. Wouldn't it be better and just easier to hook it up to that pin?
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
  4. #84
    Dec 2005
    Quote Originally Posted by checksum
    Some installs have electrical noise or thumps while powering up the computer. Using the remote turn-on lead of the PSU powers up the amp when the ignition is turned giving this noise a chance to be heard. Turning on the amp after Windows has started will eliminate this noise. There are other ways to turn on the amp later in the power-up cycle like using a delay switch. Personally, if DTR works like I expect, I prefer it over a delay switch because it will be more precise about turning on the amp at the right time after Windows is booted.
  5. #85
    Jul 2004
    Irvine, Cal
    does anyone have a update on this program? Or is it done with
  6. #86
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    no need for a update it runs like it should if you can't download it from the links check my car thread i have a link there.
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
  7. #87
    Banned
    Jun 2006
    Can someone please post up the DB9 pinout including each wire color and its corresponding pins?
  8. #88
    Nov 2006
    I was thinking I would just write some code to turn the volume down, kind of like a good home stereo will do when it's powered off. That way if I get out of the car with the vol up high, when I go to leave for work at 6am I don't wake everyone up
  9. #89
    Jul 2004
    Irvine, Cal
    Quote Originally Posted by mplex2000 View Post
    confused
  10. #90
    Banned
    Jun 2006
    Go with the DTR method, works perfect.
