Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: MediaRunner v0.01 BETA DevBuild
    Aug 2003
    MediaRunner v0.03 BETA DevBuild
    2/19/04 - Using Microsoft Tablet SDK, the GPS now has handwritting reconization.
    2/5/04 - What do you think of this front page?
    2/3/04 - Upto version 0.03, adding some logging and the mp3 area is working better. If it crashes on you can you please email any screenshots/log files that it generates. Thanks for all the help. Also a heads up, this is pre-beta, I have distributing the development builds which will have bugs in them
    thanks
    Project name: MediaRunner
    Latest version: v0.03
    OS Supported: developing and tested on XP
    Project Type: open source (GNU)
    Supported functions Phase 1: MapPoint, MP3 Player (internal, WinAmp, or WMP9), Video (divx/DVD) (internal most likely aka DirectShow)
    Supported function Phase 2: Camera (webcam), Games (for passenger), calculator, scibble (a notepad without needing a keyboard)
    Skins: your choice
    language: C#
    Currently working:
    - mainscreen/music is fully skinnable with the ability to put the icons anyplace,
    - mp3player (winamp) is almost done, need some testing
    - Video is 90% done, needs some testing. But you can search and play videos
    - MapPoint is half done, you can search and find a location. Need to activate the GPS
    - Security is 90% done, need some testing. It allows you to have a usb keydrive that will activate the program or disable it if unplugged.
    - File Sync, not completed. Will sync your mp3 with your home server most likely using tftp and windows authenication. The home server will need to run the tftp server either on the console or as a NT service.
    - apps not completed
    Dont forget the modify the MediaRunner.exe.config to meet your needs, the readme.txt tells you more.
    I would love to find out people reactions to the program. It is a work in process, and I am going to work on the performance issue.
    New version updated:
    You can download the file at:
    Binary
    http://www.mendis.com/MediaRunner/MediaRunnerv0.03.zip
    Source
    http://www.mendis.com/MediaRunner/Me...rv0.02-src.zip
    Jan 2003
    Ruston, LA
    Links don't work
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Banned NightHunter's Avatar
    Dec 2003
    Milwaukee, WI
    Binary
    http://www.mendis.com/MediaRunnerv0.01.zip
    Source
    http://www.mendis.com/MediaRunnerv0.01-src.zip[/QUOTE]
    Same problem here, dead links....?
    Aug 2003
    Quote Originally Posted by frodobaggins
    Links don't work
    Sorry three issues came up, first my primary DNS server needed to restarted, I messed up on the link name, and third I have a permission issue on the source.
    I fixed the first two and will fix the permissions when I get home. But you can get the binaries.
    Low Bitrate telstargb's Avatar
    Aug 2003
    Leicester, UK
    Quote Originally Posted by mmendis
    No ......... still doesn't work
    Mondeo 1.8 Zetec : Epia 800 : 60gb drive : Lilliput 7" VGA : Sapphire USB GPS : Opus 90w : WinXP : Road Runer : Destinator
    Dec 2003
    Milwaukee, WI
    Problems with Map Point 2004, and I keep getting this error
    " Application has generated an exception that could not be handled.
    Process id=0xa40 (2624), Thread id=0x30c (780).
    Click OK to terminate the application.
    Click CANCEL to debug the application."
    Just a little FYI
    Jun 2003
    Memphis - TN
    I get that error on startup
    winamp 5 installed as well as MS framework 1.1.
    Crashes on Execution.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Jan 2003
    Ruston, LA
    Same thing here
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Aug 2003
    Seems like people are having trouble running it. Lets see, I think mappoint maybe required (will change of course). Also if it is installed and you are still getting the error, Where do you have it installed? c:\program files\mappoint....
    thanks
    sorry from the problems
    Aug 2003
    I added a new version .02, which should be better (i hope)
    Thanks for the feedback.
  1. Media-cruiser V0.01 beta nightbuild version....
    By PTCruiser in forum MediaCruiser
    Last Post: 02-08-2005, 12:32 PM
  2. Ford Focus ME Skin Beta 1
    By nitr0genics in forum ME Archive
    Last Post: 09-08-2003, 02:02 PM
  3. Beta Test 1.6.9 Available
    By CarComp in forum ME Archive
    Last Post: 12-10-2002, 11:59 AM
  4. Wanted: beta testerss for X-MP3Pad (formerly MP944)
    By PorscheMP3 in forum Software & Software Development
    Last Post: 05-07-2002, 12:58 PM
