Do I need to reboot to get rid of this rogue thread? I get no output at all at the moment when I point it to D:\SHARE\MP3\Originally Posted by hijinks21
If I move my folder will it run better? Say D:\MP3 ?
Chris.
thats a bug i have to work out.. looks like you might have closed that app and a thread was still running in the background. I think its a simple fix though.
I plan on doing your type dir layout this week. RIght now if you set D:\Share\MP3\ as your root to mass load you should get a output like
arist ----nothing---- <button>
if not let me know
'98 Explorer Sport
80% done
Chris.
moving shouldn't matter. You shouldn't need to reboot. if you close that console window the thread will die.
I'll do a test at work tomorrow with your setup and see what happens.
'98 Explorer Sport
80% done
new version.. check the first post for the run down. I have added a new directory structure
arist
album1
album2
'98 Explorer Sport
80% done
I'm having trouble getting it to work with the new directory structure. Here's what my directory structure is:
d:\MP3\Artist1\Album1
d:\MP3\Artist1\Album2
d:\MP3\Artist2\Album1
d:\MP3\Artist3\Album1
d:\MP3\Artist3\Album2
Not finding any artwork. I'll attach a screen shot of my dir structure and error I receive. I select d:\mp3 as the start directory. Let me know what I'm doing wrong.
ok new version out.. delete the art dir and just use this one..
rgardjr and ukchris i should have fixed your issues
'98 Explorer Sport
80% done
I have it running right now and its finding some of the covers. Tried this morning and it crashed after about 10 albums-I think it was probably Amazons fault. Definatley seems faster running at off peak hour. I thing I've noticed and don't have a suggestion to fix is that for any double disc or box set that has album name with a disc # it won't find ever. I'll let you know tommorow how it does after a full run. Thanks Again!Originally Posted by hijinks21
Originally Posted by rgardjr
i found that problem yesterday. I had to change how the library was grabbing the XML data from amazon to a function that can't handle http error codes like 405/500 and such. I have that problem fixed and I'll make another build asap
'98 Explorer Sport
80% done
One feature request I'd make would be for an output file that could be sorted so you could have a record of which covers weren't found. That way you could go back to those albums and manually search for covers.Originally Posted by hijinks21
