Results 1 to 3 of 3
Thread: Additional window string!
    Newbie guvi's Avatar
    Jul 2003
    Ill try to explain my problem the best way (in english... pfuh )
    For my carputer im using MediaCar.
    GPS-Software im using: Navigon-Mobilenavigar (best 4 europe i think incl. austria, germany, italy...)
    If i start the ME, all works fine. If i want to start the Mobilenavigator, the programm shows fullscreen on my display (lilliput 7") and the sound is going on.. so far.. all right.
    but if i have the navigation running, and i want to change a mp3, i have to full shutdown the nav-application and start again after the chanche.
    the checkbox "embedded" isnt very usefull. there isnt a difference between checked and unchecked.
    know i found in the ME-setting under gps the additional window string. perhaps i can solve my problem with that.
    my idea is, that the taskbar is visible when the navigation is running. so i could easily change the programs without shutting down something.
    or any other ideas?!
    thank you,
    The Spanish Style...
    SEAT LEON! My CARPC-Install or the thread up here
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Change your screen dimensions for ME so that the task bar is still visible. Instead of 800x600 make it 800x540 or something like that. You'll have to adjust for your screen. This works for me using MediaCar and I'm pretty sure you can do the same in ME.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    The "additional window search string" will be part of the name of your GPS software. For example, I would try entering *navigator* as the string. Providing the software has a title of "blahblahNavigatorblah" then it will find it, and run it embedded in MediaCar. Then, you can use the Exit (rather than close) at the top of the screen to get back to the main menu of MediaCar, without closing down the GPS software fully
    Hopefully coyote (the writer of MediaCar) will allow us to control the music from wherever we are in the program
    Co-Developer of A.I.M.E.E
  1. iGuidance splash/disclaimer window
    By UncleGeek in forum GPS
    Last Post: 09-20-2004, 11:12 PM
  2. LCD in rear window
    By ryanerb in forum LCD/Display
    Last Post: 11-21-2003, 09:45 AM
  3. Active window upon booting xp
    By zx3chris in forum Software & Software Development
    Last Post: 09-30-2002, 11:02 PM
  4. Replies: 0
    Last Post: 08-28-2002, 05:23 PM
  5. Pioneer Slot DVD plexi window mod
    By moahdib in forum General Hardware Discussion
    Last Post: 01-24-2002, 01:55 AM
