Results 1 to 10 of 12
Thread: Windows XP MEDIA CENTER EDITION
    Constant Bitrate Sway's Avatar
    Dec 2003
    Muncie, Indiana
    has any one tried Windows XP MEDIA CENTER EDITION? If so what are your thought about it?
    http://www.microsoft.com/windowsxp/m...rs/default.asp
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by Sway
    Not for a Carpc but.... Click Here To See The Letscommunicate.co.uk HTPC DVD Project
    Terran
    Feb 2004
    Colorado
    media center isn't great for a carpc, but it you have a htpc its awesome for that. I tried if for a couple days in the car but just plain xp with mp3car or mediaengine works great
    Jan 2004
    st charles, mo
    what they said. im running it on my car pc but i just use media car.
    Dec 2003
    Muncie, Indiana
    how did you guys get it? i search for it and couldnt find a place to get it at
    Nov 2003
    You can't buy only the software. You can either get a PC that comes with it or from the MSDN site (if you have an OS membership).
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Quote Originally Posted by Izik
    What hardware does it support? What are the benefits? Is the MSDN version limited duration, does it require activation in the same way other versions of XP do? Could you tell us a little about the plusses and minusses?
    Chris.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Why is it not good for a car pc? I use it and it works great. to answer your ??? ukchris.
    If you are using the TV capture part then it requires specific hardware but even that is easy to come by. I don't do any PVR stuff in my car so no biggie there. It will support pretty much what ever Win XP supports. I think the benefits are it does what I want it to in one app with no issues, it looks cool, has animated menus, blah blah blah. BUT I wish it was skinable as it is not. The only other things I wish it did was play .MOV files and had a little easier interface for toouch screens as the Vol control is a little small. No, the MSDN version is not limited and yes it does require activation if it is to be used legally.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Aug 2003
    Quote Originally Posted by forum
    What was your impression of the handwritting reconziation on a touch screen of you have tried it. I am in the process if writing a carpc program using some handwriting features of the tabletpc OS.
    Aug 2003
    Quote Originally Posted by ukchris
    Chris.
    The tablepc version of XP is the same as XP Professional except it has the speech and handwritting reconization engine built in. In *theory* you should be able to D/L the TabletPC 1.5 SDK (11Mb) and the TRPSetup.exe (222Mb) from micorosft site. The SDK will install fine, but the other one will contains the actual engines which will fail to install on a standard xp pro install. You could extract the needed files from the cabs and use it that way. Like I said in theory this should work, I haven't tried it.
    I do have the MSDN version and I enjoy it, I am in the process of writing a carpc program which utilies the handwriting for maps routes (gps), email, fax, Web Browser (write in the url). Because it is just another application on top of XP Pro you can use any hardware you like. I would like to think of a neg but cant.
  1. Replies: 3
    Last Post: 12-23-2007, 08:39 AM
  2. Got a beta copy of Media Center for XP
    By ddt in forum Software & Software Development
    Last Post: 06-11-2006, 08:13 AM
  3. windows xp media center edition
    By the_spy_guy in forum XP MCE
    Last Post: 04-15-2006, 03:26 PM
  4. XP Media Center Edition???
    By sq_geek in forum Software & Software Development
    Last Post: 09-19-2003, 02:54 AM
  5. Installed XP Media Center.
    By Spec-V in forum XP MCE
    Last Post: 03-28-2003, 11:13 AM
