Results 1 to 3 of 3
Thread: Visual Basic and a grapic equilizer
    Aug 2003
    Does anyone know where I can get a decent graphic equlizer or occiliscope that can be integrated into VB.net? fmod dosent work worth anything for vb.net and I cant find anything else that does that kind of stuff.
    Mar 2004
    The problem your going to find is alot of the graphic eq's for VB require a specific type of sound card. If your go to your sound prefs(volume controls), and you don't see an "eq" level meter next to your main volume, the odds are good you don't have one.
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    The only way I've found is to use a plugin called VBLink for Winamp. It is a non-managed plugin which converts waveform data into a standard DLL (or something like that). At any rate, VB can get Vis data.
    I'm sure it would work with .NET, too.
    It's a little too slow to be accurate, but is good for a show. I've only run it on 300MHz machines, so a newer 1GHz+ may work better.
    http://www.softwarecave.com/
    -Pat
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
