Results 1 to 10 of 11
Thread: Avi convertor
    Jan 2004
    Avi convertor
    I need a simple program that will convert my 1gig+ .avi files to .mpg
    I've looked but i cannot find. I found one but it was only a 'trial' program so i could only convert 1minutes worth.
    Any helpful links??
    Feb 2004
    Menlo Park, CA
    Do you plan on turning that into a VCD/DVD?
    2003 Subaru Impreza TS
    Staus: Done.. too lazy to make pictures lol.
    Jan 2004
    Basically what i've done is captured ~3minute music clips from the tv card. The only problem is that they copy in .avi file format and are about 1.5gig in size! I'm hoping if i convert these files to .mpg it'll reduce them to a more sensible 150mb or there abouts.
    Jan 2003
    Ruston, LA
    Divx or Xvid
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Constant Bitrate _maelstrom's Avatar
    Aug 2003
    WI
    - Sony XAV-7W In-Dash 7" LCD
    - Via EPIA 800MHz
    - 256MB SDRAM
    - 40GB HDD
    - Targus Wireless Remote
    - Win 98SE
    See it Here
    or Here (cardomain.com)
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Quote Originally Posted by _maelstrom
    Try Windows Movie Maker too... or Gordian Knot
    www.doom9.org
    Feb 2004
    Menlo Park, CA
    TMPGEnc is great if you want to make an MPEG 1/2. However what his problem is that his original file is uncompressed. This is not a characteristic of an AVI. AVI is basically a storage standard for Audio and Video Interleaves. To get the best size-to-quality ratio you will want to re-encode the video in either DivX or XviD.
    DivX and XviD are both MPEG 4 codecs. VCD are MPEG 1 and DVDs and SVCDs are MPEG2. You wont be able to use TMPGEnc to do a DivX or XviD encoding. I would reccomend using VirtualDub(www.virtualdub.org). Also visit www.doom9.net and www.vcdhelp.com for lots of encoding and decoding information as well as links to everything mentioned above.
    Also to shave a few extra bits and bytes off that you will also want to re-encode the video into MP3 or OGG. MP3 may be a better choice because its a wider standard.
    Good luck, let us know if you need anything else.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Maeveth
    he means audio there for anyone who is confused.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Nov 2003
    Massachusetts
    Quote Originally Posted by frodobaggins
    Does Dr.DivX take AVI as input? I'd almost given up on creating DivX movies until I found Dr DivX, it was just all way too involved. Dr DivX works a treat.
    www.divx.com
    Chris.
    Jan 2004
    Thanks for all your help so far.
    I've downloaded and tried to use Vidomi, but 2 problems prevail. 1: Mediacar will not read DivX format, so need to convert to mpg, 2: Every time i tried to convert the file, it only converts the sound (no image)?!?
  1. Dc Dc convertor and Sumicom
    By tyronepatterson in forum Power Supplies
    Last Post: 02-21-2004, 12:00 AM
  2. Anyone using Amtrade DC-DC convertor?
    By Tony S in forum Power Supplies
    Last Post: 06-08-2003, 11:05 AM
  3. FireWire Internal Convertor
    By FireWireMan in forum Classified Archive
    Last Post: 03-25-2002, 01:30 PM
  4. Replies: 12
    Last Post: 09-25-2001, 11:12 PM
  5. 2.5" to 3.5" convertor
    By GrahamS in forum General Hardware Discussion
    Last Post: 11-28-1999, 10:12 AM
