Results 1 to 9 of 9
Thread: Importing Into MapPoint
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    If I capture NMEA data from my GPS and import it into MapPoint 04 the locations are incorrect, does anyone have experience with converting NMEA style LAT/LON into whatever it is MapPoint is expecting to keep it accurate?
    Chris.
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    nmea data is not in lat and long anyway. its in decimal. i have it.. for some reason i don't think it works in the EU.. but i'll give you an example of my code
    So pretty much the section is in degrees and minutes.. the first chunk is free and the second is minutes and you just do the math. endpos will be the latitude
    Code:
    Private Function getCurrentLat(ByVal curstr As String) As String
        ' first we break the string apart into degrees and minutes
        degree = Mid(curstr, 1, 2)
        minutes = Mid(curstr, 3, 100)
        ' now we do the nmea to latitude conversion
        endpos = (degree + (minutes / 60))
        ' setting the label on the form also doing some formating
        lblLat = "Lat: " & Format(endpos, "00.0000")
        ' returning the value
        ' destroying vars
        degree = ""
        minutes = ""
        getCurrentLat = endpos
    End Function
    longitude is the pretty much the same but
    degree = Mid(curstr, 1, 3)
    minutes = Mid(curstr, 4, 100)
    that
    EDIT: i am not a vb programmer.. in fact i HATE VB so the code sucks i'm sure but the concepts are there
    '98 Explorer Sport
    80% done
    Nov 2003
    Massachusetts
    Quote Originally Posted by hijinks21
    That's interesting, I have my data in Excel so I can easily try different formats, I tried Degrees + Minuts/60 last nigt without much joy. Do you append the N/W onto it before importing into MapPoint?
    Chris.
    Jan 2004
    Not to be a stickler but you might want to double check that MapPoint is expecting WGS84 datum coordinates instead of NAD27 or NAD83 that is the commonly used standard in the U.S. If so you'll have to do conversion between the two datums. Otherwise you risk being off by a couple hundred feet at least if not more.
    Nov 2003
    Massachusetts
    Quote Originally Posted by siberia37
    Sticklers most welcome... I didn't even know there were WGS84 and NAD27... this is getting more complicated every minute! Is it easy to convert between the two? I do see to be off by a few hundred feet, once I reformatted anyway, until then I was somewhere near Pakistan..!!
    Chris.
    (In the US, if the name is misleading!)
    May 2002
    Albany, NY
    my code worked 100% in the US. I had some people tell me it was off in the UK but i went on a few 8 hour trips running my code and it was almost always 100% right on.
    '98 Explorer Sport
    80% done
    Nov 2003
    Massachusetts
    So... if I have:
    $GPGGA,163519.000,4248.7815,N,07106.2886,W,1,03,02 .8,00042.4,M,-32.8,M,,*5D
    This implies LAT = 4248.7815 N and LON = 07106.288 W
    So to convert
    LAT : 42 + (48.7815/60) = 42.813025
    LON : 071 + (6.288/60) = 071.1048
    Would you append the N/W pre-import - i.e. 42.813025N,071.1048W ?
    Chris.
    May 2002
    Albany, NY
    you don't need to import the N/W and such when you pass it on to mappoint. I think your issue is that Long should be a negative value for the US. try to make it -071..
    Here was my lat/long for Albany , NY area
    newlat = 42.67606
    newlong = -73.698418
    '98 Explorer Sport
    80% done
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Quote Originally Posted by ukchris
    So... if I have:
    So to convert
    Chris.
    N = +
    S = -
    E = +
    W = -
    071.1048 W = -71.1048 Mappoint will accept that.
  1. I need some help with mappoint 2002
    By allenruble in forum Software & Software Development
    Last Post: 03-15-2004, 07:02 AM
  2. Mappoint Not Installed?!?
    By hman in forum MediaCar
    Last Post: 03-06-2004, 06:24 PM
  3. BU-303 with MapPoint 2004?
    By Jeff in forum GPS
    Last Post: 02-18-2004, 09:37 PM
  4. How to integrate MapPoint?!?!
    By deadweasel in forum Software & Software Development
    Last Post: 12-01-2003, 07:56 AM
  5. Which versions of MapPoint will be supported?
    By fluidman in forum ME Archive
    Last Post: 10-06-2003, 09:09 AM
