Results 1 to 10 of 10
Thread: Mounting my LCD Upside down
    Mar 2004
    I'm planning on mounting my lilliput upside down (for cosmetic reasons
    My display drivers do not have a built in utility for rotations...I know there are some utilities out there, infact one even comes with the lcd touchpad drivers. Unfortunately its for ATI and Nvidia drivers and my carpc is sis.
    Anyone know of a simple utility to acomplish this for me?
    tnx
    Asus Pundit Barebones PC
    7" Lilliput LCD
    P4 2.8ghz 512mb 120gb
    Windows XP Pro, VOICES
    Sony Xplode 10in Sub, Rockford 600w amp
    Pioneer 6x9's and 4x6's, Kenwood 4ch amp
    Black Widow Alarm with Pager
    Jul 2003
    So. Cal.
    Quote Originally Posted by ryguy
    tnx
    why you turning it upside down? are you taking it out of the case? if not, you could just turn the lcd itself upside down inside the case, could work. get out your dremel for the holes on the other side. also, i think, powerstrip might do this in software somehow
    Mar 2004
    Quote Originally Posted by welthqa
    The lilliput has a 'bulge' on the bottom which causes the lcd to lean inward rather than outward (pointing down). I was planning on using the casing and just using the mounting bracket that is included on the back of the lcd...
    Sound like a good idea or do you think i should take the casing off or what?
    7" Lilliput LCD
    Jan 2003
    Ruston, LA
    I would try to physically flip the lcd in the casing, so down is actually up.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jul 2003
    So. Cal.
    Quote Originally Posted by frodobaggins
    my sentiments exactly. I'm not sure if you're going to stick it on the roof ryguy or what. but if the actual plastic case the lcd and touchscreen are in is going to be upside down, turn the lcd and TS upside down in the case. You may be able to turn the backside of the case upside down with them and still have the screw holes line up, and the monitor's plugs line up correctly in the back. submit a pic or two and we'll see what more we can do
    Mar 2004
    I want to put it in my dash...but the way the dashboard is made it doesn't sit right without it being upside down. Now if i flip it upside down, do i need to cut new holes for the buttons? Or can i just leave the case off?
    7" Lilliput LCD
    Mar 2004
    Anyone have any suggestions for flipping the display upside down? I know the lilliput touchscreen utility comes with a utility to do this, however it only supports nvida and ati. Any other suggestions? tnx
    7" Lilliput LCD
    Jan 2004
    Sweden
    I have done that with my lilliput
    I use a software called Pivot to rotate picture 180 deg.
    http://www.portrait.com/
    It's a trialware (but I can help you with that if you like it)
    Mar 2004
    Quote Originally Posted by storm
    Excellent! i'll give it a try tonight, thanks Storm! astalavista for the 'fix' ?
    7" Lilliput LCD
    Mar 2004
    I guess then my video in would be upside down too...if i ever decided i wanted to use it. Is there a way to just rotate the screen and not the buttons? or is it all attached?
    7" Lilliput LCD
  1. Designing a double-din case for 2003 WRX
    By Giuliano in forum General Hardware Discussion
    Last Post: 03-26-2004, 11:19 PM
  2. This thing any good for easy LCD mounting?
    By WWE-TicK in forum LCD/Display
    Last Post: 03-20-2004, 03:10 PM
  3. Running into some issues mounting LCD
    By briang in forum LCD/Display
    Last Post: 03-15-2004, 01:54 AM
  4. mounting redant in-dash lcd
    By switch in forum LCD/Display
    Last Post: 06-24-2002, 09:29 AM
  5. Redant 7in LCD mounting questions
    By Birrman54 in forum LCD/Display
    Last Post: 04-03-2002, 06:19 AM
