Results 1 to 10 of 11
Thread: Which OS?
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    Which OS?
    Hi all,
    I'm looking at getting the MII 1.2 GHz Mobo. The question is which OS do you think I should run?
    1) 2000
    2) ME
    3) XP
    4) XP Pro
    So which one and why? And before any Linux fans come along and tell me number 5), I'm don't plan on using Linux.
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
    Oct 2003
    Tampa, FL
    Well, you listed only one OS - just different versions. Use Windows!
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    My opinion is ME.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Windows 98. Sorry but Me is crap. True you have bugs with both but Me has it worse.
    If you have enough RAM I would try XP Pro as well. Depends on what you plan on doing.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by Defiler
    Try cut down XP pro, can't go back to 98/ME ever again. ME = More Errors
    May 2003
    Czech rep.
    Right, just lot of current software does not simply work on Win98 (SE) so lot of hacking and updates would be needed in order to get things like BlueTooth stack, Mozilla or even MediaEngine working. Other then that, I agree.
    XP is wise choice too, depending on size you have to achieve. You can strip WinME down to 120 MB or even more, You will probably not succeed in getting WinXP below 400 MB.
    W2K - no way.
    Dec 2003
    ATL GA
    XP Pro is definitely the way to go.
    It's more stable,
    support more products,
    has better security if you go wifi
    ok Linux fans, I know you can shoot holes through two out of three of those, but I'm only comparing across Windows versions
    Truely, Linux could be the ultimate way to go, but I have yet to find anything as easy to work with as Windows XP. Plenty of registry hacks and settings to help configure for this usage. But eventually someone will compile a really good, fast, Linux kernel and develope a good shell to for what we need. The part that's holding it all back is that we're not all using the same hardware, and have different needs and tastes for this PC. That kinda helps lean things back in Windows favor.
    Mar 2004
    XP PRO definately (but you will need enough RAM). Its by far more stable than any other Windows so far, tons of adjustments that you can do. Windows ME is only good if you want to exit and enter your car once in a while
    As good as linux is, there is no normal GPS software for it.
    One question out of curiousity why MII 1.2? For the same price you can have Athlon XP-M >2000+ with RAM included.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Size and power consumptoin are two main reasons
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by antimatter
    And I was told size didn't matter
  1. The Os and The Car
    By SjLucky in forum Software & Software Development
    Last Post: 06-24-2004, 03:09 PM
  2. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  3. my opinion as Linux as an OS for carputing
    By churnopol in forum Software & Software Development
    Last Post: 05-05-2003, 01:56 AM
  4. An OS made specifically for EPIA M
    Last Post: 04-27-2003, 08:34 PM
  5. Which OS?
    By accord in forum Software & Software Development
    Last Post: 11-22-2001, 09:22 PM
