Those of you running Street Atlas 2004 on small touchscreens - how do you have the software configured? Even with the "Route" tab as the default on start-up, Street Atlas requires the following sequence to map out a route:
1) Change start to "GPS Start"
2) Click "Finish" field
3) Type in destination using on-screen keyboard and press enter
4) Click "directions"
5) Click "GPS Track"
6) Click "Show turns"
Obviously, this is a lot of steps and the fields are very small (and located at the bottom of the screen). Is there a way to simplify the process?
Also, Leadtek TV2000 uses a very small on-screen control panel for changing radio or TV stations. Other than going to 640x480 resolution or lower, is there a way to increase the font/display sizes of these programs?
