I've only tested this on three systems and it has worked on each ones. Can I ask you for the text of the crash so I can debug? You're in TN I see so you should've left the MAP Set to North America
-G
I did, and it crashes on me as well.
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
-G
Hi
This is the error I get.
peterj
I get same as above but different id's
Okay that's not so useful because I have no idea what bit is crashing. So I've created a new version with a different exception handler, that should hopefuly give more info. You'll be able to copy the text from the error box and paste it into the message you send back. Please download this version (same location) and let me know how it goes. I appreciate all the help! I'm sorry for the crash.
As a quick possibility did you install it to the normal location (as suggested) or put it on another drive? I'm just curious there aren't any hardcoded paths but I need to know what to try.
-grem
I originally put it on another drive but have just tried on the default with the same error.Originally Posted by Gremlin
Same with new version![]()
First let me apologise I have no clue why this isn't working. I've been trying it on other random machines and it seems okay there. So I've compiled a debug version and put it at http://www.sarinarts.com/debug autotouch setup.msi so that you can download and hopefully it'll give you some more info that will help me figure out what's going on.
One person so far has had success, I am ashamed of that!
-Gremlin
Better than none!Originally Posted by Gremlin
Edit: and not much luck with the above page either! Link doesn't work
@Gremlin I have a complete Visual studios 2003 installed on my pc . May be thats the reason it worked. Have you tried running it on a PC that does not have Visual studio ?
Satish
